Results 1 to 8 of 8
Thread: 'lux calipers, 3sge + rwd box, BT quads, F series lsd + more
    Veteran slydar's Avatar
    Dimitri
    Default 'lux calipers, 3sge + rwd box, BT quads, F series lsd + more
    new project is up in the air at the moment. i have 2/3 options. help me decide, not all these parts can go in one car!
    hilux calipers, bolts onto xt130 strut, which also bolt onto ae86 rcas/steering arms. there are 2 versions of these, these are the lighter ones. these ones also use nissan 4 pot (s14 ect) type pads $250
    gen1 3sge
    known good running engine. have all accessories (alternator, ps pump, headers and secondaries ect) also have gen 1 and 2 dizzys (gen2 has better triggering for aftermarket ecus and lower profile for better fire wall clearance) also have low profile billet dizzy cover for COP ignition conversion
    intake is gen2 gte, more suitable for rwd/conversion to front tb.
    manual flywheel and special double row spigot bearing for rwd.
    does have one broken exhaust stud. call thread tech (mobile stud removal)
    $750
    w55 with correct extension housing for ae86 and s series bell (bolt up to above motor)
    $420
    F series LSD and 4.3. as purchased. likely to need servicing but you could be lucky. with ratio in housing $400. will seperate.
    light weight sealed battery. used these in my last 2 86s. works great. can be legally put in cabin. $90
    AE111 black top quads with TPS and I.MEC rams. hot sauce, ready to make 240hp on your big port with about 20k spent on the rest of the motor
    $450 with rams.
    GAZ gai strut inserts. brand new. short stroke, adjustable, rebuildable, revalveable, very high quality insert. same dimensions as trd short stroke (ae92) though you will need a slightly longer strut to fit them in due to the fact that a normal gland nut wont fit down around them. there is a LONG wait to have these made up.
    $400.
    ca18 coil packs and igniter. un tested. $50
    all parts are in qld on the sunny coast. pick up can be arrange for here or brisbane. post np cept the engine and box. all prices negotiable. cheers.
    will do a package deal on the engine/box.
    0449 169 185.
    78's
    Dan
    Vic
    Western Subs
    how much?
    . h i t o r i k o .
    Dimitri
    $450 with rams.
    78's
    Senior Member 4.5AG's Avatar
    Vener
    NT
    Lyons
    will you separate the stacks?
    Dimitri
    make an offer
    78's
    Vener
    NT
    Lyons
    Default stacks
    Quote Originally Posted by slydar View Post
    make an offer
    pm'd
    Dimitri
    replied.
    78's
    Dimitri
    engine sold, box sold. out the battery in my new car.
    make offers on the rest
    78's
  1. 3sge conversion t series trd lsd wheels
    By gottago in forum Car Parts For Sale
    Last Post: 27th July 2011, 11:08 PM
  2. KAAZ LSD Brand Spanking, In Box, Suit Zenki(small axle) T Series
    By shift_rook in forum Car Parts For Sale
    Last Post: 12th January 2011, 12:54 AM
  3. North Brisbane. 3sge rwd parts, wheels, 71 pedal box.
    By egg_83 in forum Car Parts For Sale
    Last Post: 4th June 2010, 10:42 AM
  4. bt 20v v's 3sge beams
    By dehney in forum General Topics (No Technical Questions)
    Last Post: 17th July 2009, 09:12 PM
  5. st/bt quads
    By slippry in forum Technical - Questions
    Last Post: 3rd July 2008, 12:10 AM
