stop being a gimp and post me that turbo mani.
I have cash too
2) Custom made alloy 4AGE 16V Bigport inlet manifold CA18DET throttle body with accelerator cable bracket to suit AE86. comes with TPS and wiring plug to wire straight in. NOTE: this manifold made 5 less kw on same boost as my jdm 4age manifold not sure how it would go on an NA engine.
Brand new perfect condition
looking around $100 very ONO
4) lower 3 bolt t25/8 outlet pipe to suit rex kelway 4age hi mount manifold 2.5 inch outlet and has a 1/4 inch vaccum pipe for your wastegae or phat screaming external gate, painted morpheous metalic purple. $20 ONO
5) Toyota 4AGZE Crank Angle Sensor in perfect working condition $350
6) Toyota 4AGZE pistons STANDARD bore size have gudgeons circlips and near new rings on the pistons, near brand new have done maybe 20ks, reason for selling i rebuilt my old ze and didnt realise it had a crack from no 1 cyl to the water jacket der so i got a new block and had to go oversize!! $450 ONO
7) Toyota 4AGZE piston rings standard bore go with those pistons^^ are brand new in the box NOTE: there are different types of ZE pistons not sure if these will fit any other pistons than those listed above. $150
i will post items ONLY IF YOU ARE ABLE TO EFT FUNDS TO BANK SA!!!!
You have PM
Interested in the CAS - Has the wiring plug been modified?
nar thats just the way i had it wired to my microtech the cas is normal wiring just is cut off behind the origional plug!!
next item F/S is oil and water lines and fittings to plumb your 4a to t25/8 turbo,
fittings are speedflow with ae86 oil pressure sender included used but perfect condition, SOOOOOLLLLLD
some one must want these parts to put a turbo str8 onto your 4A?
