Results 1 to 5 of 5
Thread: fuel hose sizes?
    Veteran corknose's Avatar
    Callum
    Default fuel hose sizes?
    what size is the fuel hose from the fuel line to the injectors,? on the ke with 4ag
    Jonathan
    On any 80s/90s EFI Toyota, the fuel line under the body is 8mm metal (aluminium?) and screws onto the fuel filter.
    The high pressure fuel filter is bolted to the chassis rail or body.
    The fuel line between the filter and the injector rail is rubber, but it is a specific item with banjo fittings on both ends. If you have lost the AE86-4AG item, you can use a AE112 one, just one example.
    You can of course use a VL Commodore fuel filter, some 8mm rubber hose, and some hose clamps. This means you have a Nissan, but it works quite well.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    so when going from 4AC to 4AGE in ADM AE86, must change main fuel line?..
    people say you dont have to, but i want to confirm it...
    dose
    Senior Member Roo.'s Avatar
    Andrew
    Gold Coast
    Quote Originally Posted by Rice86 View Post
    no you dont, i run a 4agze on standard fuel lines and dont have a problem with them
    Richard
    Liverpool
    sickness
    dose
  1. Where to buy 2 fuel hose?
    By PRIMRK in forum General Topics (No Technical Questions)
    Last Post: 8th May 2011, 07:31 PM
  2. adm fuel tank hose leaks
    By Aezion in forum Technical - Questions
    Last Post: 26th April 2011, 09:46 PM
  3. ae86 fuel return hose size?? (engine bay)
    By DRFTR86 in forum Technical - Questions
    Last Post: 24th November 2009, 07:42 PM
  4. Silvertop 20v vacuum/fuel hose connections??
    By dtour in forum Technical - Questions
    Last Post: 19th August 2009, 06:09 PM
  5. Where does this hose go??
    By Rv86 in forum Technical - Questions
    Last Post: 2nd October 2008, 12:35 AM
