Results 1 to 4 of 4
Thread: digital dash symbols
    Thumbs down
    well i just started up my car today and took it for a drive and theres this light that says check
    which i got no idea what I'm supposed to check can someone tell me?
    and the light that says "brake!" is always on too but hbrake is down and I'm not on the brakes?
    can someone tell me how to get these lights off? going for rwc tomorrow
    thanks.
    Veteran driftism's Avatar
    Andrew
    Watsoia
    you can unplug the globes from the cluster, which will probably help you through your roadworthy.
    you should also check your brake fluid level, as that triggers the brake warning light as well. check engine can come on for a number of reasons, which you check through the diagnosis block in your engine bay. there is a 4age manual on here which has all the error codes in it.
    brake fluid is almost full from what i saw is there anything else anyone has had problems with?
    Andrew
    Watsoia
    could be a faulty switch on either the handbrake or the brake master itself, maybe another option to check out
  1. Digital dash
    By khai2298 in forum Technical - Questions
    Last Post: 23rd March 2011, 06:58 PM
  2. Anyone with a Digital Dash?
    By Stain in forum Technical - Questions
    Last Post: 28th December 2010, 04:28 PM
  3. A/M Digital Dash??
    By Beau in forum Technical - Questions
    Last Post: 5th March 2009, 11:00 AM
  4. Digital dash
    By Touge205 in forum General Topics (No Technical Questions)
    Last Post: 30th November 2006, 08:58 PM
  5. Digital Dash
    By Monk in forum Technical - Questions
    Last Post: 11th November 2006, 11:42 AM
