Using a smallport TB for the record.
I did modify it to suit the RWD manifold breather (drilling out one side and expoxied the other up). But the cut 'n' shut job is done in such a way that the original breather line is welded over and sealed. I haven't double checked it, but I am pretty sure the port in the throttle body is blocked off on the current manifold now too. Will check again.
Idle control is still the original thermostatic system, but it seems to still work as when warm the idle comes down to about 1800 rpm.
I'll check the butterfly on the throttle body too, it isn't actually meant to seal entirely is it? I know mine is at a slight angle when the throttle is released. And would allow a tiny bit of air in. Where would it normally pull air from on idle?
