Results 1 to 9 of 9
Thread: How to tell what JDM diff i've got
    Member jy086's Avatar
    Nunawading
    Default How to tell what JDM diff i've got
    Hi guys, just brought a jdm diff, with anti roll bar brackets.
    how to tell what model AE86 was the diff out off? thanks
    and how to tell what LSD is inside, thanks
    Jonathan
    -see if it has drum brakes or disk brakes
    -count the number of studs holding the carrier to the housing, 8 or 10
    -see if it has a "LSD oil only" sticker on the back (probably fallen off)
    -take the oil filler plug off and insert a camera like what doctors use
    Nunawading
    all i know is disk brake and 10 studs....when you turn the drive shaft both axel turns the same way....
    Coolangatta
    only way to know for sure is to take the axles out and the carrier off. Then measure the axles or count the splines (though the bearings will give it away if they're really wide - Kouki). Look at the diff centre and you'll be able to see if it's open or LSD. Or post a pic if you're not sure and someone will ID for you.
    Jonathan
    Quote Originally Posted by Chrisso View Post
    the bearings will give it away if they're really wide - Kouki.
    Not quite right sorry. The wide bearings mean disk brakes.
    Seamus
    Milton
    Jonny Rochester:
    Robo86's diff (axles) have very wide bearings
    Drum brake and it's definitely kouki
    Jonathan
    For all AE86 and AE85, both in Japan, Europe etc... there is no difference between early bearings and late model bearings. The T series drum brake versions have a normal bearing like a old Celica. The disk brake version has wide double row bearings.
    What Robo86 has is modifyed by the sounds of it.
    Senior Member aaron's Avatar
    Aaron
    NOR
    So i have a disk brake t-series with 10 studs holding the carrier to the housing. What does that mean it was originally out of?
    It did have a "Lsd oil only" sticker aswell
    Jonathan
    Quote Originally Posted by aaron View Post
    TE71 GT (twincam models, coupe or sedan or hardtop etc)
    AE86 GTV or Apex in Japan
    AE86 GT-S in USA
  1. Replies: 0
    Last Post: 1st July 2012, 01:36 PM
  2. Replies: 11
    Last Post: 26th July 2011, 11:22 AM
  3. Stupid driving you've seen
    By Frak in forum Offtopic Discussions
    Last Post: 27th August 2009, 05:04 PM
