Page 2 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 11 to 20 of 85
Thread: The Suspension Setup Thread
  1. #11
    Oldschool Member
    Mar 2008
    one thing that will need to be taken into account when talling people to max out their castor is whether or not you have rose-jointed control arms....
    a good stable setup would be +3.5
  2. #12
    well i don't have rose jointed anything, would it matter? hey slippery is that setup nice around corners or are u more of a kick it out sorta guy
  3. #13
    Oldschool Member
    Mar 2008
    rose jointed control arms will change the 'actual' castor alignment
    with a bushed control arm you max out the castor rod, but the control arm can't move freely into the castor, so it pulls back abit
    with a rose jointed control arm, you max out the castor rod, and with the minimal resistance due to the Spherical ball in the joint, your control arms will move into the castor with near 0 resistance and have no "pull back" on them...
    ofcourse this also changes if you are running rosejointed castor rods with bushed or rose jointed control arms
  4. #14
    Senior Member sr_rolla's Avatar
    beau
    Bathurst
    when i said maxed out, i meant because i had no more gaurd clearance with 205/50/15's on mine and with a street orientated car that is setup for an improvement over standard as opposed to going all out, you wouldn't really want to cut up gaurds.
    I also had stock camber at 2 inches under standard hieght (like -.3 degrees from memory) and i found mine to be good at 4 degrees castor.
  5. #15
    Oldschool Member
    Mar 2008
    i see what you mean now....
  6. #16
    beau
    Bathurst
    thread updated, if anybody has any ideas on other things to discuss in the 1st post, let me know
  7. #17
    Veteran slydar's Avatar
    Dimitri
    nice post. would be sticky if i were still a mod.
    re roll centers.. generally speaking, on a lowered car with rcas, do you think it is of benefit to lower the rear roll center?
    i will be building a diff soon, and have noticed most production based live axle race cars, where the rules allow, the panhard bar is quite alot lower than it ends up on a lowered sprinter.
    i have asked one person who has performed this mod on an ra40 and he said it made a big (positive) difference.
    for this reason i was thinking of lowering the panhard bar mount on the diff down until the panhard bar was level with it anchored on the body at the stock location.
    further down the track when i rose joint everything i will make it adjustable at both ends, as i will be re making the mounts to suit imperial rod ends
    anyway.
    but do you think this is a wise baseline to work from? (ph bar level)
    apart from other evidence mentioned above, i also liken this to the use of traction brackets.. basically youre lowering the diff within its mounts like what an rca does at the front, so i don't see how i could go wrong.. unless I'm missing something.
    78's
  8. #18
    Anthony
    Yeah great information. My only gripe would be to avoid going out of your way to widen the drift/grip divide. The information is equally useful to both disciplines so I'd hate to see someone interested in drift to disregard it
  9. #19
    Oldschool Member
    Apr 2007
    THIS THREAD IS GOOD, SOMEONE SHOULD MAKE ONE FOR DRIFTING
  10. #20
    beau
    Bathurst
    1st post updated just for you SLYDAR
    seriously tho, with regards to the panard bar, unless you make all the 4 link bars equal length and parellel with each other and the ground, the best thing to do would be to make a panard bar thats hieght adjustable at the body and diff end and just stuff around with it till your happy. There are ways of measuring where the rear roll center will end up whilst using un-parellel 4 link bars but it still comes down to how it feels to you. With the traction brackets, i assume that the idea is to lower the diff end of the lower rear links? I havent seen them but if thats the case they can work well. If they lower the links to the point that they are paralell with the ground it can only be a good thing, for best results (if thats what these traction brackets do) i would also run equal length, paralell top bars and correct the pinion angle while i was there, as i assume the nose of the diff points up at the floor atm if your car is severly lowered.
    Then with a height adjustable panard bar, the rear roll center will be the center of the bar so easy to see, let alone work out.
    Anthony: Whilst i can see what your saying and i appreciate that drifters and grip guys can share parts and information, they are in effect chasing different goals. A grip driver wants to make the best possible use of the grip he has and will try as hard as possible to avoid excess slip and a drifter wants a car that can hold a high speed, stable, controllable slide and have the car controlable after grip has been mostly lost. Anything that involves car control can be shared between the two but to many other things are at odds. I'm all for uniting the 2 factions of drift and grip but what i think we really need, as loc33e said, is a thread like this but for drift, and unfortunately theres not enough good tested theory on drift atm to do that.
    The main reason I put the title up the way i did was to hopefully avoid people putting up drift setups and confusing the thread but as u said, some of the principles in here can be used for drift...
    Well that and i know stuff all about drifting :teehee:
  1. Your Suspension Setup
    By sonsta in forum Technical - Articles
    Last Post: 30th April 2014, 01:39 PM
  2. (SA) *E7*/86 BC/AJPS Rear Suspension setup/ 2871r turbo setup
    By sleeper_13 in forum Car Parts For Sale
    Last Post: 25th July 2012, 01:06 AM
  3. The Suspension Setup Thread
    By sr_rolla in forum Technical - Articles
    Last Post: 6th February 2011, 09:18 PM
  4. suspension setup
    By AE86_4life in forum Technical - Questions
    Last Post: 1st November 2006, 08:43 PM
