Page 6 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 51 to 60 of 85
Thread: The Suspension Setup Thread
  1. #51
    gunbz-r
    I've never heard that about that ratio, makes sense, thanks dude.
  2. #52
    Oldschool Member
    May 2008
    can anyone explain how to adjust camber tops ei where to put the 4 bolts for what camber ? or anyone got a link to a guide?
  3. #53
    Oldschool Member
    Mar 2008
    there is no "guide", as too many other things factor into the results....
    if you don't know what your doing, take it to a wheel aligner....only way to get it right.....
  4. #54
    Senior Member sr_rolla's Avatar
    beau
    Bathurst
    agreed with F EDERAL, take it to a wheel aligner, to make it easer in the future, get the wheel aligner to get a few settings (2, 2.5 degrees neg etc) and mark them out on the strut tops> It makes it easier to change your settings later on
  5. #55
    Oldschool Member
    Mar 2008
    ^^+1
    just remember that if you change control arms, castor setup, etc, it will all have an effect
  6. #56
    Senior Member stylz's Avatar
    Art
    Melb
    One quick question guys. How do i get suspesion droop?
    Atm I'm running tokico short stroke shocks on all 4 corners with 10kg front and 8kg rear springs, i don't know the hieght of the springs but the cas sits slightly above legal height.
    I plan on going 8/6 or 7/5 rates as i like doin hills runs and dori.
    So what do i need to do to get 2 inches of droop? Do i need longer springs or do i need to get rid of my short stroke shocks?
    The write up explains what it is but not how to achieve it :/
    VLNY
  7. #57
    Veteran Konakid's Avatar
    Henry
    Eastern
    Droop is easy to measure, simply measure the distance from your guard edge to the ground, then jack the car up by the chassis until the tyre 'just' starts to lift up. Now measure the disance between the guard line and the ground. the difference in these measurements is the amount of droop you have.
    Say the shocks are 2 inches shorter than stock at full stroke for example, you car will need to be at least 2 inches lower than standard to have as much droop relative to what is has from the factory.
    Hope that helps!
  8. #58
    beau
    Bathurst
    a more acurate way to do it is find a place with a 4 post hoist, the ones that lift the cat by the wheels, and measure the shock/struts at static hieght. then lift the car by the chassis and measure the extended langths. The difference will be your droop measurment. In a car that is driven on shitty roads i would aim for closer 2 3 inches if its driven on good roads aim closer 2 2 inches
  9. #59
    Art
    Melb
    yeap, done that and found i have shit all droop. how do i go about setting it up to have more droop?
    i have tokico short strokes in atm and I'm not sure what i have to do :/
    VLNY
  10. #60
    Henry
    Eastern
    How much is shit all?
  1. Your Suspension Setup
    By sonsta in forum Technical - Articles
    Last Post: 30th April 2014, 01:39 PM
  2. (SA) *E7*/86 BC/AJPS Rear Suspension setup/ 2871r turbo setup
    By sleeper_13 in forum Car Parts For Sale
    Last Post: 25th July 2012, 01:06 AM
  3. The Suspension Setup Thread
    By sr_rolla in forum Technical - Articles
    Last Post: 6th February 2011, 09:18 PM
  4. suspension setup
    By AE86_4life in forum Technical - Questions
    Last Post: 1st November 2006, 08:43 PM
