you can but the 4ac doesnt a baffle
can a 4age sump be used on a 4ac? i would assume so since its a 4a block, but just making sure
30kw club
thanks
30kw club
Bigport 4age and 4ac are the same, except the 4age have the windage tray. Any other 4age sump is compatible too
compatible if you redrill the bolt holes..
They're different.. i wanted to put a smallport sump/windage tray on my bigport block & found this out
Exactly which holes are different? I put a bigport sump on my gze and it was the same :s
