Results 1 to 10 of 14
Thread: Ae86 wheel offset ?
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Default Ae86 wheel offset ?
    Hi guys , what is the best offset for rims on a AE86 with 6.5" or 7" x15" ???
    Member skiddlz's Avatar
    Josh
    Out West
    best offset without body alteration?? ... none lols..
    nah seriously 0 to -5
    depends how low you go!
    Veteran Konakid's Avatar
    Henry
    Eastern
    Why so skinny wheels?
    I would never recommend anything less than 15x7.5 or 14x7 with offsets closest to zero or slightly negative are sweet.
    Paul
    Just so you know anything with a -ve offset will be illegal on a std suspension setup due to the increase in track.
    Paul
    Henry
    Eastern
    In most states any increase of over 13mm of track per side is illegal.
    So you're stuck with a 7J +20 being the lowest offset if you want to be legal. But thats just lame.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    everything you do is already illegal
    dose
    Paul
    It is actually an increase in track or more that 25mm total (I was thinking per side) The std rims are a +27 offset so the max is actually +15, also the max tyre size is a 215 based on a 175 or 235 based on a 185. This equates to a 7.5" or 8.5" rim respectivly.
    Regards
    Paul
    Bob
    ACT
    Weston
    Thanks guys , I should have mentioned that this car is going to be used as track / hill climb car , not going to rego it. That is why I bought it cheap. Previous owner , could not get rego without engineers report.
    Regards Bob
    gay
    n1gger land
    n1gger land
    south korea seoul
    im actually going for the track DECREASE look on my ae86... track increase can be illegal, so im going to use 20 by 3.5s with a positive 75 offset.
    yeah boi starting a new trend AND remaining legal !
    Paul
    it is illegal to reduce track at all in Australia but I guess you don't really care about that at all
  1. Wheel Offset / Tyre Size Calculator
    By Kid Karola in forum Technical - Articles
    Last Post: 1st August 2009, 07:58 PM
  2. Wheel widths and offset for my hachi
    By drift kid in forum Technical - Questions
    Last Post: 30th December 2008, 11:25 PM
  3. Wheel offset calculator
    By Jarrod in forum Technical - Articles
    Last Post: 23rd September 2008, 07:06 PM
  4. Wheel Offset Calculator
    By 741 in forum General Topics (No Technical Questions)
    Last Post: 16th December 2007, 03:49 PM
  5. Wheel Offset
    By nightdevil in forum Technical - Questions
    Last Post: 4th December 2005, 09:46 AM
