Results 1 to 5 of 5
Thread: Thread measurements
    Senior Member grantobius's Avatar
    grantobius
    nsw
    newy
    aus
    hello l was wondering if any1 no's what the thread size is on 4ac oil pressure so l can buy correct adaptor for my aftermarkey guage. Thanx
    Blacktop 7age reppin
    Jonathan
    I have answered this a few times now. From memory the Toyota/Nissan/Mitsubishi oil fitting is 1/8" BST 28tpi. The aftermarket oil pressure sensor is 1/8" NPT 27tpi.
    Please seach and see if I got it right. It could be the other way around.
    Senior Member riceburner's Avatar
    Might be backwards there johnny
    I have an adaptor here in the shed to suit a 1/8" npt sender and my factory oil pressure sendor is a direct fit. Well it seems to be, doesnt appear to crossthread at all.
    1/8" bst 28tpi and 1/8"npt 27tpi arent all that different (works on my dads 150psi air compressor), in reality thread tap will still seal it, considering its only 5-7mm of thread anyways.
    Insert witty comment here....
    Oldschool Member
    Mar 2005
    Roy
    Bris
    I asked this one a while ago, but still haven't been arsed to do anything about it.
    Jonathan
    I confirm that I am right. I fit gauges at work, sometimes once a week. I did one today.
    Japanese engine block is 1/8" BSW
    Aftermarket gauges are 1/8" NPT or NTP or whatever.
    Don't force the wrong one, its just a bad thing. It will crossthread.
    Today I bought a VDO T piece from Burson. The original pressure switch screws in the far end. The aftermarket sensor screws in the side.
  1. Decal Measurements?
    By zerosktz in forum Technical - Questions
    Last Post: 10th October 2012, 01:33 PM
  2. Steering Uni Joint Measurements?
    By Ktas in forum Technical - Questions
    Last Post: 30th June 2012, 02:10 PM
  3. Brake Line Measurements
    By bigm in forum Technical - Questions
    Last Post: 19th March 2010, 08:34 PM
  4. AE86 vs RA40 hub and strut measurements
    By takai in forum Technical - Questions
    Last Post: 13th October 2009, 01:51 PM
  5. NRCA Measurements ???
    By hilux05 in forum General Topics (No Technical Questions)
    Last Post: 16th July 2006, 08:08 PM
