Results 1 to 4 of 4
Thread: engine problem
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    Default engine problem
    hey guys/girls, im having some problem with my 4age in my 86. the motor is a jdm 4age with jdm engine wiring and jdm dash wiring in a adm 86. the setup is running a s15 fuel pump.
    PROBLEM : engine hunts at 1000rpm - 2000rpm at idle and sometime revs just stay at 2000rpm and makes a slight poping noise. rev cuts out at 4000rpm.
    thanks for reading and hope you can help me
    Veteran Nikkojoe's Avatar
    Tom
    Problem 1: you have a Vac leak and/or incorrectly set tps.
    Problem 2: Your engine is running in limp mode, incorrectly set timing, or your fuel supply is weak. Make sure your s15 pump is not a low pressure pump. A vl external pump is a nice common high pressure pump.
    Problem 3: You already created a thread about this before, there is no reason to make multiple threads on the same topic.... http://www.ae86drivingclub.com.au/fo...ead.php?t=5117
    Phuoc
    Liverpool
    thakns nikko. would running an vl external and adm cradle in a jdm tank surge?
  • #4
    Tom
    It will still surge when the fuel gets very low, but not as much as a straight adm tank and cradle with external pump.
    You could get an ae82 4age cradle and pump and modify the pickup so it sits at the base of the tank.
  • Similar Threads
    1. Shuddering Engine Problem
      By pnda86 in forum Technical - Questions
      Last Post: 6th December 2010, 10:37 AM
    2. problem with engine light
      By stej in forum Technical - Questions
      Last Post: 27th February 2008, 09:58 PM
    3. Problem with brakes (spongy when engine running)
      By jase ek in forum Technical - Questions
      Last Post: 11th December 2007, 01:42 AM
    4. Engine problem...
      By DRFT - 86 in forum Technical - Questions
      Last Post: 21st June 2007, 10:22 PM
