Results 1 to 8 of 8
Thread: 4age injectors HELP PLEASE!!!
    Default 4age injectors HELP PLEASE!!!
    Hi all
    Im having issues with my motor not starting its got spark and all injectors have poer and it is gettin fuel but the injectors wont pulse even know they have power???? please help
    mick
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Sigh, why is it that people seem to think that everybody knows their exact car and setup.
    Please include:
    Type of engine
    Type of car
    Who wired it (pro, factory or backyard)
    And every single other important detail about your motor which you haven't mentioned.
    Jonathan
    If its a standard 4A-GE car, check the EFI fuse in the engine bay. Then check both the main relay and the EFI relay click when you turn the ignition one. (The injectors get power from a different relay).
    If its a custom car, then at least check the ECU has power.
    Basicaly, you just check the ECU has power and earth. Then follow the wires from the injectors back to the ECU.
    Lots of reasons why, but probably a bad connection somewhere.
    hey, yea sorry i forgot to write i am doing a 4ag conversion into my ke70.
    i have power to ecu.
    spark. power to injectors etc
    but they will not switch,
    as much help appreciated thanks
    Jonathan
    How do you know they don't switch? You need to hook up a light to one plug to see.
    Quote Originally Posted by Jonny Rochester View Post
    Yea but I cant here them tick or anything. im trying to do it all atm.
    Jonathan
    Look at the wires between the dizzy and the igniter/coil and the ECU.
    Veteran Nikkojoe's Avatar
    Tom
    Make sure both sides of injector plugs have 12V on ignition. Make sure ecu gets constant 12V for battery wire and 12v on ignition for +B and +B1 pins.
    If its all good and the engine has not been used in a while, the injectors are probably a little stuck. Best to try cranking it with a little start ya bastard in the intake. Eventually it will come good. Either that or drop the injectors in thinners for a few hours, should loosen them up (remove all seals off the first though).
  1. Replies: 2
    Last Post: 2nd September 2012, 08:44 PM
  2. 4AGE Injectors
    By cbjaust in forum Technical - Questions
    Last Post: 7th May 2010, 01:45 PM
  3. 4age injectors
    By superbmobile in forum Technical - Questions
    Last Post: 22nd August 2008, 12:28 PM
  4. 4age injectors
    By yoshimitsu9 in forum Technical - Questions
    Last Post: 6th November 2007, 08:37 AM
  5. 4AGE injectors
    By Hachi Roku in forum Technical - Questions
    Last Post: 5th May 2006, 10:24 PM
