Results 1 to 8 of 8
Thread: Diagnostics codes on ADM cluster..
    Reeece
    Casula
    Default Diagnostics codes on ADM cluster..
    Hey guys ive got a 4agte in my adm sprinter , was wondering how does one check for error codes on his engine/ecu if there is no check engine light on the adm cluster ?? or is there one and i am blind ?
    Jonathan
    There was never a 4Agte, and it didn't come in a adm Sprinter. So you have a custom setup, and you havn't mentioned what ECU it is. Even so, it depends who wired it up. Obviously you just have to put a light in some random place in the cabin, then spend a week with a wiring diagram hooking it up.
    Reeece
    Casula
    Sorry mate i didnt make myself clear... I had a 4agze motor in my ae86 when i bought it, i converter to turbo last year, running standard ecu AFM electrics etc...
    What i have found out now the standard adm cluster doesnt have a check engine light so with my 4agze loom i cant check for diagnositc codes with my engine/ecu when i bridge out t e1 terminals. The adm engine was an 4ac which wouldnt of used an ecu so therefore check engine light wasnt needed ? thats all i needa no..
    Quote Originally Posted by Jonny Rochester View Post
    Jonathan
    You need a wiring diagram from a 4A-GZE car.
    But a wiing diagram of another Toyota, and the 4A-GZE pinouts should be enough to go on.
    Reeece
    Casula
    yer or is it possible to connect the jdm cluster to obtain the check engine light?
    Jonathan
    You have a custom car.
    You don't even have a AE86 ECU.
    Plugging in the jdm cluster is not magicaly going to give you the light, because it probably won't be wired up.
    You need a smart person, and a wiring diagram etc...
    Veteran Nikkojoe's Avatar
    Tom
    Find which pin the check engine light is on. Take the cover off your ecu and it should list it on the pcb on the body harness plug of the ecu. The code printed on the pcb for the check engine light should be W and should be a white wire.
    To wire up use a test lamp, connect one end of lamp to 12V and the other end to the check lamp pin out on body harness plug. This will get your check light working.
    Reeece
    Casula
    cheers thats all i needed
  1. Replies: 17
    Last Post: 5th January 2013, 03:20 AM
  2. ADM AE86 DASH CLUSTER
    By Gunner in forum Car Parts For Sale
    Last Post: 21st June 2012, 08:48 PM
  3. working adm cluster
    By redsprinter in forum Cars or Parts Wanted
    Last Post: 4th January 2010, 12:09 PM
  4. ae86 ADM dash cluster
    By crillman in forum Car Parts For Sale
    Last Post: 20th May 2008, 08:43 PM
  5. adm guage cluster
    By Hally in forum Car Parts For Sale
    Last Post: 20th January 2008, 02:48 PM
