Results 1 to 10 of 13
Thread: Installing a W58 into my AE86 - Any advice/info/tips???
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    hey guys,
    Iam going to be putting a W58 into my AE86 in a few weeks and iam just wondering if there is anything i need to know about doing the conversion.
    Now, i thought this would be a common topic in the tech articles section but the search wont let me search for w58 (too short) and i didn't find anything when i had a browse....
    Anyway, apart from a custom g/box mount, what else do i need to know. The engine is a smallport 4AGTE (previously GZE) and iam going to get a bellhousing off AJPS to suit.
    So, iam really just wondering what flywheel and clutches i need to use, and other stuff like bearings and forks etc.....
    Any info is much appriciated,
    Thanks guys,,
    J
    Elite rthy's Avatar
    Leo
    Tulla
    who makes the bellhousing that Dave is going to supply?
    sorry I don't have any answers for you rquestions but I am looking into finding out and writing a faq article on it.
    JoJo
    ACT
    Tuggeranong
    <div class='quotetop'>QUOTE (Sam_Q @ Apr 6 2008, 10:14 PM) </div>Not sure who makes the one dave is selling, just the ones he is selling on the AJPS site.
    Dave, can you answer this?
    john
    nsw
    liverpool
    yeah ill be interested in the clutch as well .
    can you get a custom clutch to fit the w58 box and use the standard 200mm flywheel?
    Senior Member gaz20v's Avatar
    Gareth
    Lismore
    i will be doing a w50 to my gze, ive been told my standard gze flywheel and clutch will do the job (same box spline ) and using the bellhousing adapters from niteparts etc. Aparently some of the bellhousings need a tiny bit of a clean up with a dremel to fit the standard gze flywheel inside. Dunno much more than that tho. If your using the stock flywheel why don't you use one of the adapters biggo used, uses the t50 bellhousing with a sandwich plate, much cheaper.
    see here
    Joash
    Tasmania
    North west
    When i did mine i did this
    Nite parts bellhousing (get one if you can worth the money)
    w series shifter fork
    4a throwout bearing
    Extreme 212mm 3.9kg fly wheel chrome molly
    Extreme clutch package, 4 puk sprung centre plate with s series splines, 4a pressure plate (see ajps)
    t18 slave cly
    Custom dodgy x member
    Senior Member PuGZoR's Avatar
    Andy
    Thornlands
    Remember when going to W5x you'll probably need a new tailshaft. Considering you've got a 4AGTE you're probably looking at enough power to justify getting a new one made and not just butchering a stock one. Gearbox crossmember is a big one too, most commonly people make one themself (it's easy enough with a welder). Have heard whisperings that a RA6x Celica crossmember (one that come with a W5x on it originally) should only need a couple of holes redrilled to be suitable.
    Make sure you have a clutch fork pivot too...
    Oh yeah, if you haven't already, make sure you have a spigot bearing (I think that's what it's called, it's the one that goes in the flywheel). FWD 4A engines don't have them, RWD boxes need them. Just go down to repco and ask for one to suit a standard 4AC powered sprinter, as the hole for it in the flywheels are all the same, no matter what 4A flywheel you're using. (as far as I know!)
    Joash
    Tasmania
    North west
    yea thats correct
    6001 from memory
    Elite rthy's Avatar
    Leo
    Tulla
    yeah its a 6001, make sure you buy a Japanese made one!!
    Veteran biggo's Avatar
    Nick
    Noosa
    you need a mid mount shifter housing thingy if you don't want to cut up the tunnel.
  1. Installing AE86 struts & brakes to AE71
    By slipn in forum Technical - Questions
    Last Post: 14th June 2012, 08:14 AM
  2. Installing Rear quarter windows into AE86
    By briigo82 in forum Technical - Questions
    Last Post: 2nd February 2012, 02:17 PM
  3. Need tips/info on selling me ke70
    By FAST EDDIE in forum General Topics (No Technical Questions)
    Last Post: 17th November 2011, 09:03 PM
  4. Installing AE86 front springs
    By Sidey in forum Technical - Questions
    Last Post: 18th March 2008, 10:49 PM
  5. installing a fuel pump in a AE86
    By lewwy in forum Technical - Questions
    Last Post: 20th March 2007, 08:17 PM
