Results 1 to 10 of 11
Thread: koeniggsegg ccx v8 into Cortina!
    Veteran bigm's Avatar
    Gold Coast
    Default koeniggsegg ccx v8 into Cortina!
    "The engine can produce well over 2000hp,(it wll give about 2300hp at 2.4bar boost) but turbos is its only limitation , they can produce 1750hp at the maximum in teory , so we'll se how well they hang in there.
    It even passes 1000hp before 1 bar(14.7psi) of boost.
    If we get 1500,1700 or 2000hp really doesent matter, it is only in it's drag-spec configuration it will be ble to put down these hp numbers.
    As it is now it produces 170hp at idle, 290hp at 2000rpm... and after that the turbos really kick in... so there is always enough power...!"
    Worth a read, crazy build
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    You do realise that A Koeniggsess V8 is just a quad cam ford v8. same as in our V8 falcons.
    i never seen an xr8 idle at 170hp
    Jason
    Nundah
    Thatz cause no one in Aus builds tuff quad cams....The States love them. Only pply in Oz that have put any time into the ford V8 that I'm awair of is CAPA.. think it made 1000 or so at the wheels... And 170 at idle.... WTF.. have you even seen anyone start a dyno pull from idle... Pretty sick build though... would be scary fast...
    yeah, you have many valid points.
    i still think its cool..... ford v8 or not
    Veteran slydar's Avatar
    Dimitri
    will reserve judgment till its finished. lots of work. and quite nice craftsmanship. lots of this sort of stuff happening over that side of the world.
    ect.
    78's
    Veteran drift kid's Avatar
    Glossodia
    im not a V8 fan, but this does impress me.
    Senior Member shichi~'s Avatar
    Ethan
    North Suburbs
    meh im currently dropping a w16 into my ket0
    Veteran MINIHORSE's Avatar
    Felix
    Inglewood
    Meh Meh im going Rolls Royce Jet Turbine
    Senior Member PuGZoR's Avatar
    Andy
    Thornlands
    I'm putting the complete jet system from a Harrier as primaries in my dad's VE SV6. Dunno yet, but considering the option of some B52G's engines as boosters, I hear they're cheap in Russia. Vertical takeoff will be fun, should do 9's too. Haven't bought the stuff yet, but I've done the math, should all bolt up no probs. Bugger all fabrication to do.
    But seriously, crazy builds are fun to watch. There used to be a good website that tracked some of the more promising ones, I forget the URL though...
  1. which hub is used with a magna/cortina brake upgrade
    By orangechargd86 in forum Technical - Questions
    Last Post: 21st December 2007, 01:21 PM
  2. Ford Escort / Cortina rims fit ae86 ?
    By jase ek in forum Technical - Questions
    Last Post: 8th July 2007, 08:59 PM
  3. V8 Levin
    By MrMatt in forum Toyotas in the Media
    Last Post: 15th October 2006, 09:18 PM
  4. V8 power???
    By mtgg85 in forum General Topics (No Technical Questions)
    Last Post: 31st January 2006, 10:22 AM
