Results 1 to 10 of 12
Thread: t series diff question
    Senior Member eightsixboy's Avatar
    Paul
    East
    I just received my new t seies diff and found that one of the 10 housing bolts is longer than the others and is to long for the carrier (pics). i'm thinking its maybe a jdm carrier with maybe t-18 diff in it?
    Any ideas?
    P.S sorry bout image size lol
    Paul
    East
    I spoke to a mate and he rekons its the wrong diff, the longer bolt is there for a different casing to accomodate 4.11 gears ie bigger pinion?
    I'll be pissed :verymad: if its like 3.7 or 3.9 cause i was told it had 4.11 gearing and he knew i was gonna go to 4.3 soon.
    I'll have to pull it apart tonight and have a closer look.
    Veteran deleta's Avatar
    Callum
    Queensland
    Wynnum
    if its the wrong diff , i have a center slash carier thats 4.11 that may be avliable soon this has the longer bolt
  • #4
    Rob
    Moorabbin
    Hi i didnt assemble the diff personally, i will look into it, but should be 4.11 tho
  • #5
    Hugh
    Is that a S series centre? I thought T series have a different carrier housing. Ie both have same bolt spacing but T series has extra bit for longer bolt. Have a look at the pic in this thread:
    http://www.ae86drivingclub.com.au/board/in...showtopic=26550
    and see in the top pic near bottom left the housing has 'extension' where the bolt goes?
    Maybe someone has better pic and can correct me...
  • #6
    Rob
    Moorabbin
    t series centre = 10 bolt
    s series centre = 8 bolt
  • #7
    Hugh
    thought I was wrong, had my T18 diff too long.
    In this thread http://www.ae86drivingclub.com.au/board/in...=3965&st=60
    'Javal' describes a difference in celica and T18 diff centres regarding the long bolt.
    I think this is closer to the problem?
  • #8
    Senior Member sr_rolla's Avatar
    beau
    Bathurst
    correct, the celica housing has a longer stud in it, a mate of mine had the same problem, just swap it over with a stud from something else that fits, or leave it out if your really dodgy :2thumbs:
  • #9
    Rob
    Moorabbin
    +1 to this ^^... I just grabbed one of the short studs out of my old s series and it was sweet... Celica diffs (commonly 4.1) seem have this wheras the t18 diff has the long one for some reason....
    Count the teeth to figure out the gearing, its probably a 41 crown and 10 pinion making it 4.1 (not 4.11), these come out of plenty of celicas....
  • #10
    Site Supporter Javal's Avatar
    Josho
    <div class='quotetop'>QUOTE (sr_rolla @ Apr 11 2008, 11:54 PM) <{POST_SNAPBACK}></div>
    correct, the celica housing has a longer stud in it, a mate of mine had the same problem, just swap it over with a stud from something else that fits, or leave it out if your really dodgy :2thumbs:[/b]
    Best course of action, right here.
  • Page 1 of 2 1 2 LastLast
    1. Replies: 0
      Last Post: 1st July 2012, 01:36 PM
    2. Replies: 14
      Last Post: 4th June 2012, 07:16 PM
    3. T-series diff question
      By E7 PIG in forum Technical - Questions
      Last Post: 21st June 2010, 08:45 AM
    4. t series Diff question.
      By aussie freestylers in forum Technical - Questions
      Last Post: 1st April 2010, 12:24 PM
    5. s series diff question
      By shinny in forum Technical - Questions
      Last Post: 15th September 2007, 06:49 PM
