Results 1 to 10 of 10
Thread: no cooling fan???
    jamie
    queensland
    coolangatta
    Question no cooling fan???
    hi there
    quick question??
    ive just bought an AE86 with a 4AGE
    and i only just realised it doesnt have a fan behind the radiator?? it doesnt have air con either, dont really care bout that. it doesnt overheat at all. should i be concerned and get a fan?? or is it not required??
    thanks
    Kieran
    i'd just hook a thermo fan up to it just in case
    Alex
    Wagga Wagga
    Afaik, fans are there to draw air through the radiator when there is no air flow through it, ie, sitting at the lights/traffic. Should be fine in normal driving with air passing through it though. I think I did read in another thread that Sam_Q (?) runs his 20v with no fan, and hasn't had overheating issues to date. That being said, depending on your location, the weather will have a lot to do with cooling issues. If you just bought it recently, be aware that it WILL be hotter in summer as opposed to now, going into winter. To be safe I would spend the small amount of money to buy a thermo switch and a $50 thermo fan from supercheap auto.
    Aaron
    In the Mountains
    either a automatic switch or manual switch for the thermo, dont having it running all the time so it warms up quicker and when just crusing it will help to keep it up at a higher temp. when it cold i.e. of a night or really early mornings my bus struggles to get upto full operating temp due to a bit of a over kill sized radiator. but atleast it doesnt get hot any more i guess
    Alex
    Wagga Wagga
    Yeah no need to have one on permanently. Get a Davies Craig thermo switch. Easy as to install and you'll never have to worry about turning the fan on/off manually. Just set temperature and away you go.
    jamie
    queensland
    coolangatta
    so where would ya hook the thermo switch up 2??
    Jonathan
    Even when driving along, (mostly regulated to 50km/h these days) a fan cools the rad much better than not having one. I had trouble with a regular Camry overheating, untill I found the electric fans were stuffed.
    If you have a RWD waterpump, it is far easier to to put the stock fan on with the mechanical clutch. But if you have to buy the viscous clutch new, a electric one may work out cheaper, but the mechanical one will work very well. And use the plastic shroud also. The undertray, plus bits of foam and rubber in various gaps (which came from the factory) all assist in cooling.
    Nathan
    Lilydale
    also just to add that if you are using a toyota external thermostat (ae82/92 etc.) the housing has a switch in it that can be setup to control the thermo fans via a relay.
    works well.
    Timmy D
    North
    I bought a kit from jay car that monitors falling voltage wired it into the sensor at the back of the head. now i have full control of when the fan turns on and off. havent had a chance to set it up in driving conditions yet but after running for around 3-4 min she kicks the fan in. another option if your handy with a soldering iron
    JJ
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Quote Originally Posted by Sprinter86 View Post
    works well.
    If you're not, you can still use the inlet off the ae82, ae92 thermostat with your rwd 4ac or 4age pump and use the integrated thermo switch.
  1. Clutch fan VS non Clutch fan 4age water pumps
    By hachirusto in forum Technical - Questions
    Last Post: 17th April 2012, 04:01 PM
  2. 4age 16v fan fan clutch
    By hutto_t in forum Cars or Parts Wanted
    Last Post: 31st March 2010, 03:28 PM
  3. Cooling issues
    By Blizzerd in forum Technical - Questions
    Last Post: 9th October 2009, 08:00 PM
  4. 4AC Cooling
    By Fusion in forum Technical - Questions
    Last Post: 6th July 2009, 08:15 PM
  5. GZE cooling
    By .wolfwood in forum Technical - Questions
    Last Post: 16th July 2006, 08:30 PM
