Results 1 to 10 of 14
Thread: Will a speedo read higher on smaller wheeles or otherway around ?
    kravit
    bowen hills
    Question Will a speedo read higher on smaller wheeles or otherway around ?
    Hey guys,
    I have AE92 with 14 inch wheels with low profiles.
    I was wondering if my speedo is more then likely to read higher on the dash, but I'm actually going slower ? or is it other way around ?
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    think about it
    your car is moving the same distance and smaller wheels will take a shorter distance to move a full 360degrees.
    this means at a true 80km/h your smaller wheels will be spinning faster than the larger diameter.
    this means that with smaller wheels than standard your speedo will be reading higher than you actually will be going
    kravit
    bowen hills
    Ahh okay cheers for very well put explanation
    Least I'm going under the speed limits then
    Gone
    Joel
    Picton
    the smaller the wheel the further and faster it must travel to travel the same distance and at the same speed as a wheel with greater diameter.
    Veteran blair's Avatar
    Blair
    Sheldon
    ^ depends on the tyre tho...
    out of interest, what 'low profile' tyres did u get for 14's?
    Gone
    Joel
    Picton
    Quote Originally Posted by blair View Post
    i did mean with tyre.. i should have said total diameter including rubber.
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by sundee86 View Post
    Also known as the rolling circumference
    Rob
    Moorabbin
    Nope, diameter is diameter, circumference is circumference, they are different
    Josho
    Quote Originally Posted by RobertoX View Post
    You know what i mean brotato
    Jon
    Durack
    well there is a way to find out if your wheel size is the same size as your standards.
    but i forget the maths behind it lol
    a 205/60/R14 is the same rolling size as a 205/50/R15 if that makes any sence.
    hence why larger wheels have lower profile tyres
  1. Replies: 11
    Last Post: 30th January 2011, 03:56 PM
  2. Seats, what is there in a smaller than average size
    By Chrisrundell69 in forum General Topics (No Technical Questions)
    Last Post: 4th August 2010, 09:17 PM
  3. 4.3 or higher
    By stouty in forum Cars or Parts Wanted
    Last Post: 23rd April 2009, 10:15 PM
  4. How to make pics smaller
    By The_81 in forum Offtopic Discussions
    Last Post: 28th December 2007, 05:20 PM
  5. Effects of smaller steering wheel?
    By shelldrake in forum Technical - Questions
    Last Post: 8th May 2005, 09:11 PM
