Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 37
Thread: 7AGE (16v or 20v)
  1. #11
    Veteran starni_boy's Avatar
    Clint
    Sutherland Shire
    added some pics..
    more to add tomorrow sometime.
  2. #12
    Veteran slydar's Avatar
    Dimitri
    yeah thats what i meant, standard rwd brackets.
    how close is the sump to the x member?
    78's
  3. #13
    Clint
    Sutherland Shire
    There is a bit of room there. The same as a 4age I would guess. Will get a pic for you now.
  4. #14
    Dimitri
    i am just thinking once you have the engine supported by the mounts, it will sag, and foul, as this is what people have found in the past, though it would be nice if it didnt.
    78's
  5. #15
    Clint
    Sutherland Shire
    ^^There should be enough room height wise, maybe it might be too wide and hit the back of the sump. But it should clear hieght wise it has about 40-50mm clearance there.
    ^^This pic was taken on a slight angle, so the X-member actually sits in between the deep part of the sump and the bolts. It has about 20mm clearance there on the closest lower edge.
    Going to update my members ride thread now.. Rust FTL.
    Did you want any other pics Slydar? I have a few here but can get some if need be.
  6. #16
    Dimitri
    nah don't need more photos. just seems odd that it doesnt hit, as that is one of the problems you hear of always.
    mostly just mentioning for your sake and others who are reading.
    the washers under the engine mount nuts atleast do seem pretty high, are sure the stud coming out of the mount is bottomed out in the x member?
    78's
  7. #17
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    it can't go any lower as the 2 claw looking thing come up over the top of the mount on x member
    MY JZX83 (clicky)
  8. #18
    Felix
    Gold Coast
    Here is my clearance front & rear
    Engine mounts
    and water situation - custom radiator = win
    no drama's at all
    Note: this is with a 16V head
  9. #19
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    How hard would this engine rev to?
    is it only 5500rpm?
    and also, is it a hassle to cut into the firwall?
  10. #20
    riojin
    stock internals its safe to rev to 7500. if you flog anything hard enough itll break. if you want peace of mind buy aftermarket rods. its suggested you do to start with but it depends on how often youll be flogging it
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. AE86 7age 20v, Sydney
    By adm86 in forum Cars for Sale (Toyota Only)
    Last Post: 12th December 2010, 12:14 PM
  3. 20v blacktop 7age ae86
    By grantobius in forum Cars for Sale (Toyota Only)
    Last Post: 21st March 2010, 03:27 PM
  4. 4age 16v vs 1.8 7age 16v
    By stx-16 in forum Technical - Questions
    Last Post: 11th November 2009, 02:14 PM
