Results 1 to 3 of 3
Thread: sTUCK IN 5TH
    Jack
    Nsw
    North shore
    Default sTUCK IN 5TH
    Had the gear box reco,
    get it home after 11 ks , its stuck in 5th...
    what could this be caused by?
    the bearings are new
    the guy said
    "might be the selector"
    im about to boot this car...
    can anyone help or shed light i want to drive this tomorrow.
    thanks and regards
    Jack Ritchie
    Senior Member dave2221's Avatar
    if its just been reco'd
    take back and tell them its their problem
    apart from that..... sledgehammer will sort it out.
    Nic
    Mt Evelyn
    i had this problem when i was changing the bellhousing on my sr20 box. turned out the reverse switch/sensor was jaming one of the gears!! after about an hour or mucking round just took it out and went on like a treat.
    hope it helps
  • Similar Threads
    1. my 5th xe7x
      By Evan in forum KE70 / AE71 Owners Forums
      Last Post: 19th August 2010, 11:02 AM
    2. drums are stuck
      By shinny in forum Technical - Questions
      Last Post: 5th February 2009, 08:04 PM
    3. Clutch is stuck?
      By grape_moosha in forum Technical - Questions
      Last Post: 20th August 2007, 12:26 AM
    4. Stuck valve...
      By browneye in forum Technical - Questions
      Last Post: 22nd June 2007, 12:14 PM
    5. supercharger stuck
      By Jake_Crawf in forum Technical - Questions
      Last Post: 21st August 2006, 06:29 PM
