Results 1 to 3 of 3
Thread: pulling gearbox out
    okay i have a gearbox to go in my ae71 with a 4age. I am also doing these things while its on stands.
    4link put in
    new clutch master cylinder
    check condition of 3000km old clutch
    flywheel condition
    zorst mounts due to snapped manifold bolts grrrrrr
    empty 2way oil and refill
    trd rear adjustable shocks in
    engine crossmember swap over
    is there anything else i should check while its on stands?
    also i have to swap my engine crossmember over should I take the weight of the motor and
    drop it out from the bottom or just rip out the motor and box together?.
    i have taken the gearbox from under neath the car before and its easy but
    just wondering if i should take the lot out and check other things while in there?
    cheers dan
    ae71 parts for sale stripping 3xae71's and a ke70
    Veteran biggo's Avatar
    Nick
    Noosa
    check all lines under the car, be on the look out for oil.
    If your swapping everything out by yourself, pull motor out with a crane/block and tackle, then just undo the xmember, if you got a mate id say give it a shot with the motor in/weight off, be carefull with the steering rack too
    edit* stick a welder under there too, see what happens :teehee:
    lol a welder? yeah ill seam weld it too lol.
    nah i have another shell to do that to
  • Similar Threads
    1. CA Gearbox, T50 Gearbox, Ecu's,Exhaust QLD
      By damien454 in forum Car Parts For Sale
      Last Post: 23rd July 2012, 01:02 AM
    2. Pulling down a 7afe engine - Removing crank bearing caps
      By Matt in forum Technical - Questions
      Last Post: 15th May 2012, 07:14 PM
    3. Why is my car pulling to the right hard?
      Last Post: 3rd December 2009, 09:33 PM
    4. Car pulling to the right
      By -=GOODY=- in forum Technical - Questions
      Last Post: 29th November 2007, 09:56 PM
    5. Tips for pulling axel?
      By aaron_drift in forum Technical - Questions
      Last Post: 19th October 2006, 06:02 PM
