Results 1 to 4 of 4
Thread: What t50 do i got????
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    Default What t50 do i got????
    Well i have 2 oddball boxes the first one is in my ke70 4ag. I was under the impression that ae86 and 71 t50 are the only ones with the correct splines and bellhousings for 4ag and 4ac style.
    THis box i have in the car everything is correct, splines, 5 speed, shifter but had a different bellhousing and had the origional seals in ti so hasnt been changed, drivers side clutch????? WHere did it come from????
    THe other one i have
    splines are correct for 86/71 not sure if its 5 or 4 speed, bellhousing is not 4a, the 4 bolt flange that holds the throwout bearing is a different shape and the shifter provision in the selector shaft has a diameter smaller hole in it than your usual 4a shifter???? WTF is that fom???
    AE86 THE BEST
    Jonathan
    Late model TE72. Tailshaft spline same as AE86. Clutch on right side. Fits T series motors.
    Eddie
    sa
    ohk then that works with the first box but what about the one with the small shifter hole??
    AE86 THE BEST
  • #4
    Jonathan
    The T50 has 2 shifter positions. (Two different shifter housings and gear levers). But length of the gearbox and output shaft is the same.
    The early T50 (TA22, TA23 Celica, TA12 Carina, TE27 Corolla, TE37 Corolla, TE47 Sprinter) has the forward position where the gearstick links dirrectly with the 3 rods in the box.
    The later T50s (TE72, TE71, AE86, AE71) have a more rearward shifter position where the shifter has a nylon ball on the end, and it uses and extension rod in the box.
  • Similar Threads
    1. Replies: 9
      Last Post: 1st September 2012, 12:31 PM
    2. Excellent condition t50 or broken t50 with good second gear.
      By munki in forum Cars or Parts Wanted
      Last Post: 25th May 2011, 02:10 AM
    3. Wtb: t50 parts or jap t50
      By richo in forum Cars or Parts Wanted
      Last Post: 15th February 2011, 12:50 PM
    4. JDM t50 bellhousing c/w free T50
      By oz_eight6 in forum Car Parts For Sale
      Last Post: 9th May 2010, 02:23 PM
    5. t50 4A bell -> t50 2T gbox seal problem
      By PULSE in forum Technical - Questions
      Last Post: 15th June 2008, 12:29 PM
