If it's leaking from the drain plug, then drain it, wind some plumbers tape around the thread of the drain plug, then check if it leaks again.
Hey guys, my fuel tank has a bit of a leak. Seems to be coming from the drain plug.
I did a quick search and could find an answer on what i should use to fix it. Although i did read that i shouldn't use silicone.
I was thinking of using JB weld, but its heaps hard to find
Thanks for any help
^yes, ensure you use an oxy acetylene welder too..........
............or don't.
How do u undo the plug. Looks like a big disc. No nut or n e thing to grab onto
Its on a KE70 btw
<div class='quotetop'>QUOTE (aimre @ Apr 23 2008, 08:19 PM) </div>It has a 1/2" square indent in it.
Use a 1/2" extension bar and ratchet to undo it.
Fuel will spew out. I suppose you knew that.
plumbers tape might get eaten away.
Maybe just check to see if its loose?
<div class='quotetop'>QUOTE (Javal @ Apr 23 2008, 08:51 PM) </div>
Ah yeah. I couldnt see it cos my cars too low. I can feel it but. Will try the teflon tape on friday
if it is the tank i would get another one. you would almost get one for nothing.
not worth the hassle of catching on fire while welding it. haha.
<div class='quotetop'>QUOTE (steroidchickens @ Apr 23 2008, 10:40 PM) </div>
No way i would weld it.
Ill try just tightenging it, or teflon taping it, then tightening it.
If it still leaks, ill buy some JB Weld from the US and 'cold' weld it
People have used this stuff on engine blocks and it holds... Ment to be really good stuff
