Results 1 to 4 of 4
Thread: firing problem
    callum
    qld
    tully
    Default firing problem
    hey all.
    i pulled all my turbo gear off. manifold, cas, and fittings. left it for a few weeks. then put it all back on again.(to investigate an exaust leak) after i put it all back on again, the starter motor cranks, and it goes wewewewewewewewe for ages, but it just wont kick into life, it pops every now and then (igniting unburned fuel i guess). iv got a marking on the cas which iv always matched up whenever iv taken it off. and its always gone fine. dad reckons it seems to be trying to fire 180 degrees out. does this seem like a reasonable diagnosis? how can i rectafy this.
    any suggestions are appreciated.
    callum.
    your friendly neabourhood electrition. for cash jobs pm me!
    callum
    qld
    tully
    nah i didnt tought the plugs or leads, but ill look at em
    Veteran slide86's Avatar
    Huw
    Hills
    definetly sounds like the timing is out
    excessive cranking and popping are a few of the big symptoms of incorrect timing
  • #4
    callum
    qld
    tully
    got it started. i just played around with with the cas. still has a mad exaust leak but. lol
  • Similar Threads
    1. new cams on 4ge but not firing
      By dehney in forum Technical - Questions
      Last Post: 27th March 2011, 12:06 PM
    2. AE71 not firing after manual conversion
      By Ben 1 in forum Technical - Questions
      Last Post: 29th August 2010, 09:37 PM
    3. 3T-C not firing on one cyl
      By mish86 in forum Technical - Questions
      Last Post: 27th February 2009, 07:21 AM
    4. firing order for a 4ag
      By TRD_86 in forum General Topics (No Technical Questions)
      Last Post: 20th February 2008, 08:19 PM
    5. 4age firing on two cylinders
      By fozz in forum Technical - Questions
      Last Post: 26th March 2006, 11:12 AM
