Results 1 to 10 of 19
Thread: ae 101 4agze complete motor
    item: ae101 4agze motor (set up for FWD)
    condition: great! recent rebuild
    extra info: will come with everything needed, supercharger, alternator, dizzy, loom, ecu, radiator, etc etc
    will come with a 2 1/2 exhaust? pod filter, fmic with plumming 2 suit fwd
    approx 80,xxx kms on motor has had recent rebuild
    located in the northern suburbs of Adelaide (pick up only)
    can view motor running
    price: $1,400 firm
    contact: on here, pm or sms/ mobile (plz ring after 4pm as i work night shift)
    thanks
    -Jarryd
    0432642256
    Oldschool Member
    Aug 2007
    I'm guessing this is supercharged. Any idea on how much to convert to rwd?
    yes supercharged, sorry
    all u need is ur inlet manilfold and exhaust manifold, providing u have a ae86 or ae71 etc
    depends what cooler setup you use to? $1 per meter for felxi hose @ bunnings for a cheap/ temp fix
  • #4
    Veteran Nikkojoe's Avatar
    Tom
    <div class='quotetop'>QUOTE (jarryd @ Apr 30 2008, 12:37 PM) <{POST_SNAPBACK}></div>
    extra info: will come with everything needed,....dizzy,.., airflow[/b]
    Uh, dizzy and afm sounds like aw11 gze
    Also will need a 212 or 200mm flywheel and clutch for rwd to the clutch plate splines mate to t50 and flywheel to clear bellhousing
    still good price
  • #5
    well its got a dizzy 4 sure, so i guess it might be the better version
  • #6
    Tom
    If by dizzy you mean distributor and single coil (and not cas and coil packs), the it definately would be an aw11 gze which is the first gen of gze's. (uses afm not map)
    AE92 S1(cas and afm)
    AE92 S2(cas and map)
    AE101 is a cas and map
  • #7
    Thurston
    Vic
    North East
    ^ what he said. I wish people would get a clue about what theyre selling. I just bought an engine advertised as a smallport map gze and when it showed up i took one look and knew it was an early gze. Not happy Jan! So please, before you go selling things make damn sure you know what youve got!
  • #8
    100% sure its a ae101 4agze
  • #9
    Thurston
    Vic
    North East
    Check the head. Is it bigport or smallport. Because the only 4agze that had airflow meter and dizzy was the early one from an aw11 mr2. So unless the entire ecu ignition setup was changed out to an earlier one... Also take the sump off and check for oil squirters if you really want to be sure.
  • #10
    Tom
    tell me the part no. of ecu, and the pins per plug (should be on lable of ecu) and the order of the 3 plugs
  • Page 1 of 2 1 2 LastLast
    1. Replies: 5
      Last Post: 14th December 2011, 07:19 PM
    2. 4AGZE Motor complete
      By Magoo in forum Car Parts For Sale
      Last Post: 26th June 2011, 11:27 AM
    3. 99.5% complete ae 86 in south ozzy
      By sic86 in forum Cars for Sale (Toyota Only)
      Last Post: 31st March 2011, 01:58 AM
    4. Vic- SR20de motor + gear for you KE or AE
      By unr34l in forum Car Parts For Sale
      Last Post: 8th February 2011, 08:31 PM
    5. 4agze bottom end or complete motor
      By SNAP in forum Cars or Parts Wanted
      Last Post: 24th March 2008, 01:26 PM
