Looks nice, Where abouts are you from?
Usual 4agte Mods.
Currently 175kw @ 16psi.
somewhel in qld it seems
<div class='quotetop'>QUOTE (trueno_kim @ May 3 2008, 07:44 AM) </div>I'm pretty sure thats a NT plate.
is that this car?
[attachment=25482:blue8677wy.jpg]
if it is I'm sure brendo will get very excited when he sees it!
is it possible to get some better pictures man? and better specs because it looks like one mean machine!
i think i seen a video of this with a yellow 86 twinning they were both awesome!
specs of car ? =]
yeah its simon michelmores old car. the yellow car would have been crab.
78's
yeah twas crabman was an awesome video! after that all i wanted to do was learn how to control cars like they do !
Got abit of a list
Engine Type: 1.6 20v Turbo
Chassis:
Seam welded and prepared with re-enforcing in known weak areas
Hand flared wide body guards
Rear Brace
Engine:
JDM Silver top 20v head
GZE bottom end 7 rib block
Toyota GZE pistons and rings
Custom intake manifold
Custom turbo manifold
T28BB (From S15)
Turbosmart boost controller
1JZ injectors
MicroTech LTX8 Computer
MicroTech Dash Unit
BLITZ SBC spec R boost controller
Sard BOV
4 Bosch coil packs
8.8mm leads
Deka dry cell battery
Cooling:
Toyota Camry radiator
Thermos
Hybrid Intercooler
Fuel System:
Bosch VL Turbo lift pump in tank.
Bosch 044 Fuel pump
Custom 2L Surge Tank
Exhaust:
3" dump pipe off turbo
3" cat
2.5" mandrel piping after cat into one hot dog and then rear muffler.
Driveline:
W55 gearbox
Short Shifter
Custom one piece tail shaft
T18 rear end
TRD 2 way lsd with 4.1 ratio
Exedy HD 4 puck clutch
Suspension & Steering:
AE86 coilover with SW20 REAR cusco inserts fitted
8kg/mm spring, front
6kg/mm spring, rear
S13 Tein Camber tops
Random Castor rods for more castor
Power steering arms for more lock.
TRD blue 8 way adjustable rear shocks
18mm white line sway bar
Nolathane bushes all round
Rebuilt steering rack
New wheel bearings throughout
New front end bushes
Brakes:
Nissan 15/16 Master (Patrol 4x4)
Front: Nissan S13 SR Turbo front disk / Calipers on custom brackets. Bendex metal king pads
Rear: ST 141 disk / Calipers on T-18. Bendex metal king pads
Interior:
Custom dash
HeadUnit and 2 way splits (not in Pic)
Sparco bucket
4 point Harness
Standard seats
Autometer boost and oil pressure gauges
Exterior:
J-blood front bar
White Line rear tail lights
TRD wing
NO RUST
Full Respray (mid August 2007)
Wheels / Tyres:
Custom built 16x8 with -5 offset Watanebe
225/40/R16 Nankang
Id also like to see the said video if possible.
