Options:
1. Use XT130 corona struts, HiLux 4WD calipers, Peugeot disks, Corona hubs. Heaps writtin about this on Toymods. I have done it. Works well. 10" disks, 20mm thick.
2. Use AE86 struts with JDM vented disks and calipers. Smallish disks, 18mm thick.
3. Use AE86 struts with Mazda FC calipers, alloy adapter brackets (AJPS), Civic disks. 10.5", 21mm thick.
4. Use TA22/23 struts with AE86 brakes. I have a pair of AE86 brackets with a hole drilled for TA22 if you like.
5. Use TA22/23 struts with 4spot calipers, Civic or similar disks, and custom brackets.
6. RA23 or RA40 front brakes and struts. Not vented, so hardly worth it.
7. Tarago/Camry/whatever front brake calipers, make your own bracket. I have early Tarago brakes to sell you.
