Results 1 to 10 of 15
Thread: R31 barkes onto t series
    Senior Member FLT LNR's Avatar
    Mitch
    Default R31 barkes onto t series
    Ive just installed a t series disc brake rear end into my AE71......the brakes are $&*t!!!!!!
    what work is involved in getting r31 calipers and rotors onto the diff,
    or is there another alternative keeping in mind i want the handbrake to be as tight as possible, and no tiny drums because im sick of them popping....
    THX
    Nathan
    Lilydale
    from what ive read you can use corona RT142 rear disks on the t series with little modification, search 'corona disks on t series' in google, you might might find some good info for it.
    hope this helps,
    nath
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    So are you saying the brakes are worse now than what they were?
    Did you do anything about brake bias?
  • #4
    Senior Member Simon-KE70's Avatar
    Simon
    r31 rear calipers are notorious for being utterly junk, wouldnt be worth the effort
  • #5
    Erik
    Riverina
    go a hydro setup? or just a general freshen up of the rear setup with better quality pads?
  • #6
    Dave
    what do you mean by
    Quote Originally Posted by FLT LNR View Post
    THX
    and....
    THX
    sounds like aussierider is on the ball in the fact that you just need to do overhaul your disc rear end?
    are you talking about the handbrake sucking or the brakes (pedal/hyraulic system) being no good?
  • #7
    Paul
    Quote Originally Posted by Simon-KE70 View Post
    Gotta agree with Simon and floody on this one, R31 calipers are junk.
    As Sprinter86 suggested the corona option is good, I have this setup, disc brakes are good and drum style handbrake works very nicely
  • #8
    stefan
    vic
    eastern suburbs
    shock mounts will need re welding to clear the calipres!
    i dont know if this will work but if the r31 calipre brackets bolt on to a t series, do your self a favour and not waste time looking for corona calipres just go and get some vr commonwhore rear calipres as they are exactly the same
  • #9
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    corona upgrade are the best. i've done it and its easy. abit of drilling and cut and re weld the shock mount to clear the caliper. i have one for sale
  • #10
    Mitch
    The cylinders & shoes keep wearing out on me.....they stopped locking up and i couldn't even park on a hills when this happened......replaced a few times.....(this was on old diff)
    The JDM rear disc's and calipers arn't exactly locking up....Have considered rebuild with good sticky pads....
    Interesting about the corona setup (also looking into this commadore shit)....will look into tomorrow at a wreakers....
    THX guys
    Mitch
  • Page 1 of 2 1 2 LastLast
    1. Syd - Nissan R31 Skyline Silhouette Series 3 Manual
      By Bomfunkmc in forum Cars for Sale (Not Toyotas)
      Last Post: 21st September 2012, 07:08 PM
    2. Beige series 2 manual R31 Skyline with roady and rego! QLD
      By Pidgey in forum Cars for Sale (Not Toyotas)
      Last Post: 26th September 2011, 05:56 PM
    3. Series 3 R31 Silo
      By StuC in forum Cars for Sale (Not Toyotas)
      Last Post: 13th June 2011, 04:10 PM
    4. series 1 R31 Wagon: Chelt area Vic
      Last Post: 12th January 2010, 05:44 PM
