Good point hen, I didnt read that it was disc brake already
Note you CAN'T do the Corona disc conversion onto a T series which came with discs from the factory. The brake mount holes on the ends of the diff are in a different pattern (not the nice rectangular pattern the drum equipped T series diffs got).
I have a brand new Genuine toyota rebuild kit for Rear Calipers if you want..
sounds like you want to go twin caliper setup for this?
Was told s13 rotors and hubs will fit, only need to fab the caliper mount out for the caslipers to clear, "any info" as i have the disc and calipers already in my garage, wasn't sure if it would work however,
