Results 1 to 8 of 8
Thread: oil pressure sender questions
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    Default oil pressure sender questions
    Hi
    I have a few questions about the oil pressure sender
    1. Is the oil pressure sender in a 4ac and 4age the same?
    2. If i have a jdm whitline dash do i need the 4age oil pressure sender?
    3. Is the 4age sender the right thread size for an sr20det?
    4. Does anyone know the part number for a new 4age sender?
    Thank yoo
    Veteran Nikkojoe's Avatar
    Tom
    1. Oil pressure sender is the same for 4ac and 4age and 4agze and 20V if they run a gauge.
    2. You need any of the 4a pressure senders for it to work.
    3. No idea unless you specify the thread on an sr20det
    4. Can't answer.
    Gone
    Joel
    Picton
    i thought it wasnt a sender, i thought it was just a pressure switch?
    2. the cluster doesnt run a gauge, doesnt it just run a light?
    3. if its not take the old thread and the new thread to your local pirtek an adapter will cost u 3 bux.
  • #4
    Tom
    There are 2 types, digital clusters and SOME analogue have an oil light, not gauge. All ke70's and ae71's have oil light switches.
  • #5
    Jonathan
    Yes and No. Most AE86 use a pressure gauge. Many other cars use a light on the dash, and a pressure switch on the engine. Switch is the small one. Variable pressure sensor is the larger round one.
    Yes and No. If the dash is from a GTV or Apex, you need the larger pressure sender. If the dash is from a AE85, you may need the switch.
    Yes
    83530-30080 switch
    83520-14023 variable pressure sensor
  • #6
    Nathan
    Gold Coast
    thanks jonny your posts are always helpful
  • #7
    Nathan
    Gold Coast
    i called up toyota and its 142.80 just for the 83520-14023 variable pressure sensor does anyone know the generic parts number for repco or super cheap
  • #8
    Jonathan
    You very rarely need to know part numbers for generic stuff. You just look it up at the shop.
    I have a few of these laying around, as many people would who have wrecked a few engines. They come on AE86, and AE92 SX and any other Toyota that has a oil pressure gauge.
  • Similar Threads
    1. 4AG oil pressure sender
      By nelpd96| in forum Cars or Parts Wanted
      Last Post: 15th April 2010, 07:03 AM
    2. oil pressure sender
      By h1_roll4 in forum Cars or Parts Wanted
      Last Post: 14th August 2008, 08:21 PM
    3. Speco oil pressure gauge and sender
      By Brendo in forum Car Parts For Sale
      Last Post: 11th May 2008, 01:53 AM
    4. URGENT: Oil Pressure sender??
      By LeviNafey in forum Technical - Questions
      Last Post: 3rd February 2007, 10:48 PM
    5. oil pressure sender unit
      By AE86dori in forum Technical - Questions
      Last Post: 14th August 2006, 06:47 PM
