may have to specify more than "AJPS stuff" mate. whats the free hight of springs you have?
as stated in the heading, just wanna see what the back of peoples cars look like when theyre sitting on AJPS 230mm springs,
I'm bored at the moment and ive got heaps of AJPS stuff sitting in my garage waiting to go into my absent car so i just wanna know how excited i should be, plus i wanna get an idea of how the rear sits on springs of that height.
cheers guys. :2thumbs:
edited
title says 230mm
this is mine ajps all round. too high imo. i wanna drop it by 30mm or so with some new custom ones
what spring rate????? Sag will differ!
johl, car would look sick with 15mm less free height, 30mm prob give you scrubbing with those wheels.
Are those wheels 15 x 7 -0's or something? The Koenig B Bombs yeah?
I have 15 x 8 -4 superlights and am getting new springs in a week or two, think I might go 215mm height.
7.5 +-0 i believe.
Touge, you'll want to flare the fronts and rears to fit superlights with 195/50's at a low height (top of tyre tucked)
In my 86 I've got AJPS 230mm 6kg. It's way too high now, higher than my old body-roll set-up.
I'd say 210-215mm is the way to go with 6kg odd.
<div class='quotetop'>QUOTE (Meathead #2 @ May 10 2008, 11:10 AM) </div>Already are and have 195/50 on there.
I want to go stiffer though as I have R32 front springs cut and they arent hard enough so I couldnt really drop it to the floor. Guards are just even with the top of the tyre. front is lower with a 3 deg camber.
Probably the same height as the blue car in the rear and a bit lower in the front.
Probably rock some AJPS 6kg 215 free heights and go from there. Going to be running AJPS coils up front soon.
yeh if i don't go greddy coilovers i'l get some 205mm 6kg rears made up. how much shorter are the stock ajps front springs? i forget? i know they're shorter than the rear tho
