Results 1 to 3 of 3
Thread: heli coils and the like
    Gone
    Joel
    Picton
    Default heli coils and the like
    hey guys just wondeing if there are any other options with repairing stripped threads.. in the Head, a mates car has 2 EXT manifold threads in the head that are stripped.. leaking like a biatch! so is best option to try and helicoil the suckers or try go next 2 sizes up .. eg drill out and re tap?
    Senior Member shakes's Avatar
    Simon
    Vic
    Melb
    all depends on space and tooling.
    if you have the required tools or worse, the lack of wall thickness to drill out I'd use a heli-coil every time.
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    Are you talking about exhaust manifold studs holes? Heli-Coil.
  • Similar Threads
    1. 1NZ/1ZZ coils and 20V motors/igniter/coils
      By 70XIN in forum Technical - Questions
      Last Post: 25th April 2011, 08:54 AM
    2. 20v coils.
      By corknose in forum Technical - Questions
      Last Post: 12th November 2010, 08:31 PM
    3. bosch coils which one's?
      By J0RD0 in forum Technical - Questions
      Last Post: 12th September 2010, 08:51 PM
    4. Straight Cut Vs Heli...
      By jason in forum Technical - Questions
      Last Post: 14th November 2007, 08:12 PM
    5. Ignition Coils
      By bigm in forum Technical - Questions
      Last Post: 8th May 2006, 11:46 PM
