Results 1 to 4 of 4
Thread: more lock when turning left than right
    Jason
    Gold Coast
    Default more lock when turning left than right
    Any ideas guys, as it says, when im on full lock left there is a good amount of lock, when turned to the right it is noticably less. And there is no play in the steering as far as i can tell.
    The car has a quaife rack and power steering arms.
    recently the rack was unbolted, then bolted back on but thats about it.
    Any ideas would be a help as at the moment i have none.
    Cheers, Jase
    Senior Member julzy's Avatar
    Julian
    Parky
    Your rack isnt centered,
    the tie rods have to be the same length.
    Needs a good wheel alignment
    Quote Originally Posted by resol View Post
    i slide 3rd gear corners in the dry on the street, and 100km/h entry's.
    Akio
    Mt Haruna
    Japan
    its previously been set to a prefered dori side. get an alignment and it will be fine..
  • #4
    West
    I used to run corona control arms and corona tie rod tubes, which made it physically impossible to have the rack off centre. There wasnt enough thread to mis-align it on the tie rod and rack ends.
  • Similar Threads
    1. Knocking noise when turning left
      By toniies in forum Technical - Questions
      Last Post: 2nd January 2013, 06:41 PM
    2. whine in steering when turning left
      By blake. in forum Technical - Questions
      Last Post: 26th October 2009, 07:32 PM
    3. Steering questions, quicker turning/lock
      By shifty5 in forum Technical - Questions
      Last Post: 19th January 2007, 11:51 AM
    4. Steering heavy when turning left ?
      By HiLtOn in forum General Topics (No Technical Questions)
      Last Post: 3rd August 2006, 01:33 AM
