Results 11 to 20 of 23
Thread: Wheel fitment pics with details
  1. #11
    Veteran driftke70's Avatar
    Ryan
    Buderim
    front 14 x 8 -16 185.60.14 semi flare, standard + 20mm lca negative 10mm clearance
    rear 14 x 9 - 20 195 60 14 semi flare negative 20mm clearance
    wheelfriends.wordpress.com
  2. #12
    Jan 2007
    15x7" superlight +12, 205/50/15 hankook ventus k104s, std guards, kings springs, std front end.
  3. #13
    Jason
    Broadbeach
    JUST WANTED TO POINT OUT..
    Some tires stretch way more then others and clearance can and will change dramatically
    ie
    195/50/15 "on a 8" rim" potenza g3 has so much more clearnce in guards then the new re001
  4. #14
    Veteran Konakid's Avatar
    Henry
    Eastern
    Agreed, re001 doesnt stretch for shit
  5. #15
    <div class='quotetop'>QUOTE (Meathead #2 @ May 15 2008, 05:00 PM) </div>
    Stretch looks OK to me :teehee:
    Front: 15x8.5 -21, 195/50R15 RE-001, Origin +20 FRP guards (-2.5<sup>o</sup> OEM LCA)
    Rear: 15x9 -2, 195/50R15 RE-001, rolled lip (T-Series discs)
    Will find better view pics of 15x7 +3 195/50R15...<sup></sup>
  6. #16
    Henry
    Eastern
    Oh they stretch for sure but the sidewall doesn't really pull that tight like the G3's did, probably due to them not having a lip protector.
  7. #17
    Veteran slydar's Avatar
    Dimitri
    15x9 -13 195 50 ns2 (quite a wide shoulder on these)
    corona xt130 strut
    sigma control arm (1 piece version, +30mm)
    cusco tops set to max camber (4* + at a guess)
    dunno how useful that really is but can't hurt.
    fully flaired guard (hard to go much bigger without cutting/heat)
    78's
  8. #18
    Dimitri
    14x8.5 - 2
    185 60 (yokohama c drive.. or a.. the good ones.. kinda rounded tread profile, doesnt look super nice stretched)
    s series drum
    inner lip folded back (not flush, but pretty far).
    fits quite easily.
    78's
  9. #19
    Dimitri
    14x7 +4
    tyre as above.
    offset rca. (t3, 25mm offset)
    tops set to neutral.
    lip folded back dead flush, guards not flaired, just outer pushed out around 10/15mm.. fits easy.
    78's
  10. #20
    Dimitri
    14x8 watas all round (youll have to check the offset on the watanabe site, it will be around -6)
    25mm offset rca
    flair front, lipped rear - hammered out a bit.
    pretty easy fit. some rubbing, really nothing to worry about.
    import tyres, can't remember brand, 185 60 14.
    78's
  1. Fitment pics
    By sundee in forum Spirited Drive
    Last Post: 11th July 2014, 09:03 PM
  2. 15x8 +20 borbet wheel question! dnt no much about wheel fitment...
    Last Post: 13th April 2011, 11:43 AM
  3. Wheel Fitment.
    By corknose in forum Technical - Rims & Tyres
    Last Post: 4th September 2009, 09:22 PM
  4. fitment pics please
    By slippry in forum Technical - Questions
    Last Post: 2nd February 2008, 06:19 PM
  5. Wheel Fitment
    By 7om in forum General Topics (No Technical Questions)
    Last Post: 16th October 2007, 06:07 PM
