ya take out the oil light sender witch is on the top half on the passenger side of the block at the front (from memery its bellow the first and second exhaust port) replace that with a tee piece from autobarn or one of those joints (vdo i think is the brand) you have to take in your sender so they no what size the thread is
the tee piece screws into the block and leaves you with two new ports one you use to attach a braided oil line to the turbo (you will have to get made) and the other you can use for a oil pressure guage sender or be dodgy and just screw your oil light sender back in
