Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 11 to 20 of 44
Thread: SSR Mesh (how do you take the mesh out?)
  1. #11
    Oldschool Member
    Jul 2007
    ive done some pretty much the same
    get a rubber mallet and flog the shit out of it and itll pop
    putting it back in is trickier cause you have to get it perfectly straight
    use 4 opposite bolts to pull it in even
  2. #12
    Aaron
    In the Mountains
    what about welded 3 piece??
    can you get the welded part machined off so they can be separated?
  3. #13
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    I used a lump of timber on end and large hammer on the floor to separate my 2 piece SSR Meshies, quite a mission as they were very tight.
    I believe the "3" piece welded which is pretty much a 2 piece wheel can be machined/grinded and then separated. This is the process performed when wheels are "widened" when a wider outer section is then welded on.
  4. #14
    Charlie
    SE
    hey boys I ended up with a piece of wood and mallet knocked them out, sprayed em, then screwed them back in one screw by one to pull it in.....this is what they turned out like:
  5. #15
    F-ing Shmick!
    I thought you had to torque the bolts when putting them back in? Or am I trippin...
  6. #16
    Charlie
    SE
    i just put them in one buy one and pulled the mesh in, i didnt do the bolts up all the way because it wouldn't work. I put one in far enough so I could thread the next one to it, then went around and did that until all were super tight. I took me about an hour a wheel......sober saturday 7am mornings FTW!!!
  7. #17
    Jase
    South Australia
    Glenelg
    if you want to reverse them you just put them in backwards, and do exactly the same?
    or can you only reverse certain rims?
  8. #18
    Charlie
    SE
    nah man if your thinkin bout gettin positive offset mesh cheap and flipping them to get massive negative offset its not a good idea as other people will tell you. The rim of the wheel would be set up for a specific offset and if you totally reversed it, it would put massive strain on not only the rim, but also your stud bolts. Fuk buyin cheap pos offset, save some cash like me and buy neg
  9. #19
    Jase
    South Australia
    Glenelg
    well they are ssr reverse mesh with 7+ offset
    that I'm thinkin about buying
    if i reversed them would it only make it -7 then?
    its not like I'm reversing +30's
  10. #20
    Senior Member amulday's Avatar
    Amulday
    Central
    Damn Hayden they came up looking real shmick, Looks like your 86' is coming together nicely.
    amulday.sam
    HR ARMY
    RED BEAR
  1. Replies: 0
    Last Post: 15th November 2010, 07:13 PM
  2. EOI:SSR Formula Mesh & Reverse Mesh
    By poh_86 in forum Car Parts For Sale
    Last Post: 19th September 2007, 10:46 AM
