Results 1 to 10 of 10
Thread: water problems with ducktail
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    Default water problems with ducktail
    hi, im currently having some water problems with my ducktail. Everytime it rain water is leaking into my car from the seals aroung the glass. does anyone else have the same problem as me? how do i overcome this problem?
    Site Supporter Javal's Avatar
    Josho
    Replace the window seals.
    You don't want your hatch to rust.
    Mason
    Salisbury East
    If your window seal is ok & not perrished get it remove and resealed!
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    if it is the window seal how is it a problem with the duckwing?
    perhaps your duckwing has a hole for the window wiper and you have none and just a grommet in the hole, it may just be sitting the the hole for the duckwing and not actualy sealing the hole in the hatch. letting water run underneath the fibreglass and into the hatch? i know mines doing that right now because of some sweet streeter moldings...
    FTP.
    Rob
    Moorabbin
    You really need to find out where the water is coming in from. Like they said, it might be nothing to do with the ducktail wing.
    It could be the window seals, hatch seals, the wiper hole or some holes wherever the wing has been installed (i've seen them done with self tappers before). It could also be getting in through a rusty bit.
    Also depending on how the wing is sitting, it might be causing water to pool on the hatch where normally it would just drain off it. You might want to create some drainage past the wing if that is a problem.
    I've found that a good way to locate leaks is to run water from a hose slowly over bits of the car and see if it gets in. Try to narrow down where its getting by moving the hose around. On my car I thought the boot seal was leaking but it turned out the be the rear quarter windows leaking and making its way into the boot.
    Veteran drift kid's Avatar
    Glossodia
    ^^^ and how'd u fix it, mines doin tha same
    Rob
    Moorabbin
    Someone breaks into your car smashing the rear quarter window, then you call out the guy to replace the window and it doesn't leak anymore...
    ...worked for me
    Phuoc
    Liverpool
    its leaking around the seal. im thinking of using sikaflex around the seal. but the problem is that the ducktail acts as a bowl and keeps the water in and im afraid after time it will just rust around the seal..
    Josho
    Quote Originally Posted by evil86 View Post
    Well, replace or get your window seal fixed first off.
    Then either:
    a) work out a way of letting the water drain out from the bowl made by the ductail - even if that means drilling a small hole as a drain point.
    b) keep your sprinter stored undercover
    Jon
    Durack
    sounds like the seal.
    before my car hits the road again all windows will be resealed because i have the same problem
  1. Replies: 0
    Last Post: 7th October 2011, 07:37 AM
  2. 4age, rwd water pump, ae86 problems
    By Hella86 in forum Technical - Questions
    Last Post: 4th May 2011, 08:49 AM
  3. WTD, 4age water outlet, the one above the water pump
    By gaz20v in forum Cars or Parts Wanted
    Last Post: 11th December 2009, 11:56 PM
  4. Water temp problems/gauge/sendor??
    By FKN16v in forum Technical - Questions
    Last Post: 22nd April 2008, 11:56 AM
  5. ducktail wing
    By Johnny_08 in forum General Topics (No Technical Questions)
    Last Post: 11th October 2006, 01:47 PM
