Results 1 to 6 of 6
Thread: mx73 LCA replacements
    Charles
    Ok well basically I already know that there are alot of LCA's available off of other toyotas to suit 86/70/71, but I was wondering if anybody knew if these arms would fit onto a mx73 cressida in the same way or if there are longer replacement rods available.
    FYI, I have searched but found zilch on cressida's
    Cheers y'all
    Site Supporter Javal's Avatar
    Josho
    MX73 arms will be alot longer than any of the longer arms that are used for the ae86.
    Go to a pick-a-part wrecker with a tape measure, you'll find something.
    Maybe MX83?
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    yeah mx73 arms are pretty long id dare say if you put anything thats any upgrade on a 70/86 would be shorter
    My guess would be that the point where it mounts on the crossmemeber is also thicker
    Senior Member xsoarerx's Avatar
    Logan City
    you guys have it wrong (no offence)
    mx73, mz10 & ma61 are all excatly the same and rather short arms, probley some of the shortest ones you can get for a large toyota.
    they measure 280mm long from what i measures compaird to ke70 which is... 310mm?
    ill confirm that mx83 ones are longer by 20mm i think (will check with the ones i got at home) you just need to redrill the castor rod and swaybar holes and your away, it runs a similar ball joint to the s13 and x73 so you should be right to run the same BJ. and the bush is a little different but slots in no worries (from what ive been told, i need to install mine )
    i did alot of searching when i was looking into my s13 gear, can be found here.
    Charles
    Cheers for the help people, just realised I posted this in tech articles instead on tech questions lol
    A 20mm increase sounds decent enough, trying to think what the difference was with the s13 ones on my 31. The car is going to be a daily so nothing to extreme :2thumbs:
    Logan City
    S13 gear would be a pretty huge differance.
    i think s13 are 350mm? thats approx. 70mm increas each side hahahahaha MASSIVE amounts of camber
  1. [WTB URGENT]ae86 hubs brakes and struts complete and quadlight replacements?
    By El-GringoDRF774 in forum Cars or Parts Wanted
    Last Post: 18th September 2012, 12:29 PM
  2. MX73
    By Drift_Donkey in forum Other Toyotas
    Last Post: 25th October 2011, 11:53 PM
  3. Blacktop 20 valve head bolts possible replacements?
    By sdrawkcab in forum Technical - Questions
    Last Post: 14th August 2011, 01:29 AM
  4. 14 x 7's, xt130 LCA, AE86 Struts, AE86 LCA [BRIS]
    By blair in forum Car Parts For Sale
    Last Post: 3rd November 2009, 06:52 PM
  5. 4agze ingitor replacements
    Last Post: 16th May 2009, 08:43 PM
