Results 1 to 8 of 8
Thread: 4AGE 20V question
    Kemal
    DONCASTER
    AUSTRALIA
    Default 4AGE 20V question
    What needs to be done in terms of converting to 20V to RWD format, and what are the costs associated with doing this conversion. Any info would be great, as im planning on doing an engine conversion but im not 100% sure.
    Cheers.
    Jonathan
    The cost is very high, in terms of time taken to read everything on the forums.
    30 seconds to ask a question on the forums
    400 hours reading stuff on the forums.
    5 hours actualy doing it.
    Scammer, DO NOT BUY FROM ME!
    depends if you want to do it properly or not
    u can do it with stock ecu and dizzy, options are move the engine forwards or cut the firewall and have some nice long rad pipes
    or you can do it with an aftermarket ecu, proper rwd cooling kit and use the stock engine mounts. (the proper way)
    2nd option will cost more but will be a heappss better setup!
    HAHAH I LOVE BOOST LOOSING!!
  • #4
    going aftermarket ecu isnt all that expensive, if u go a razorback for $700 wired. then u just need to setup an ignition source. also removes the AFM on silvertop
    Drift skills? i thought buying an import was all you needed? well..... im screwed
    Banzai parts garage
    Action tyres southport
  • #5
    Senior Member 20v ae71's Avatar
    Dillon
    Kaizen sell a complete adaptronic setup for RWD 20v which includes COP ignition setup for $1650 i think? I was going to go down that route with mine but just ended up selling it. PM Anthony
  • #6
    Aaron
    for me, ive spent close to 4k converting my 86 to 20v. that includes halfcut, adaptronic, rs chita waterline kit, as well as all motor seals and waterpump etc
  • #7
    West
  • #8
    Quote Originally Posted by H8CHIR6KU View Post
    im not going to add up my costs,...but yea quite easily do-able
  • Similar Threads
    1. 20v 4age cam shaft question
      By pen15 in forum Technical - Questions
      Last Post: 28th May 2012, 11:49 PM
    2. 20v Silvertop N/A question
      By 20vnic in forum Technical - Questions
      Last Post: 15th August 2008, 04:44 PM
    3. 20v quick question
      By 350hp4agte in forum Technical - Questions
      Last Post: 18th October 2007, 06:39 PM
    4. quik 20v question
      By dr1ft-pig in forum Technical - Questions
      Last Post: 3rd April 2007, 04:53 PM
    5. 20v question
      Last Post: 30th August 2006, 09:36 PM
