Page 1 of 14 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 140
Thread: Converting a 3sge to RWD
    Veteran biggo's Avatar
    Nick
    Noosa
    Default Converting a 3sge to RWD
    TO REMOVE ADS, PLEASE
    REGISTER OR SIGN IN
    So i thought id write this to soothe my saturday arvo boredom. All information involes a gen 1 3sge. Im not sure about any other sort so you will be on your own if you aquire one. So lets get started:
    All pics are 2sc on the left and gen 1 3sge on the right.
    2 pennys if you can work out whats wrong here. Im going with a 2s starter, Y bellhousing users will probably use the 3s one
    Gearbox stays, 3s ones have a different bolt spacing on the bellhousing. So again im going 2s
    Rear water oulets, not sure what im going to do here?
    Companion flanges, pretty much the same, mine are 2 peice cos i think they were both auto. Not sure
    2s Sump. You will need the pick up aswell. I also got the dipstick just to be 100% sure.
    Y series bellhousings can be used to convert an S to W box, from what i know one bolt hole needs removing and replacing. Also puts the starter on the intake side.
    2S have a 6 bolt flywheel, 3S have 8, yair pretty much 4ac to 4age all over again
    The acutall power steering pump is the same, mounts and lines are different for both motors
    You will need a dual row spigot bearing to support the input of the gearbox. Someone will tell you why cos i have no idea.
    Alternator mounts are different again, so bin them. 3s normally have them high up over the exhaust in FWD. Apparently MR2 SW20 have them low on the intake side, so thats probably tour best bet.
    Thats all i can think of for now. Will update as i find shit out.
  • #2
    c
    what are your plans for the dizzy? and what ecu do you plan on running?
    Im about to do the same thing to a mates 71, I found a cheap sa63 for him so lucky on that side of things. But still tossing up what to do about the dizzy
  • #3
    Nick
    Noosa
    Gen 2 dizzy, shorter profile and has the correct pickup for an aftermarket ecu. Ill probably go Microtech if i have to buy a new one or Motec if i buy a used one.
  • #4
    Nick
    Noosa
    Gen1 dizzy vs gen 2 dizzy
  • #5
    c
    sweet ill tell my mate to look for one
  • #6
    Nick
    Noosa
    So i guess i was wrong. 2s and 3s power steer pumps have completely differnent offsets on both the mounts and the pulley.
    So i had a gander, as you do and started doing this to the 2s mount.
    I still need to grind ~3mm of the alternator to fit it perfectly. Its far better there than up ontop of the exhaust mani. But then...
    One small problem to over come. Pretty sure it will solve itself if i take the pwr steer pressure switch out and remover the front slider (it has one at the back too.)
  • #7
    Veteran slydar's Avatar
    Dimitri
    you need the long/deep double row bearing because the input shaft of the w5x is too short to engage a normal spigot bearing when placed in the crank. this is the case with all 3s engines to my knowledge. and with either sa63 or yr2x etc bells.
    you can alternatively have the bell housing milled down (approx' 5mm on each side).
    a gen 5 beams 3s (factory rwd) has the spigot bearing in the flywheel. using a factory or after market clutch/flywheel combo is an option for all other (not gen 1 na) versions of 3s. gen1 na has a different crank bolt pcd (though all 3sges are 8 bolt, the gen one is on a smaller bolt circle)
    78's
  • #8
    Veteran Konakid's Avatar
    Henry
    Eastern
    BEAMS + SA63 Bell + W55
    Happy time?
    RT142 Estate.
    AJPS.
  • #9
    Nick
    Noosa
    i think that would be "i have no money left" time.
    I also grabbed the water outlet off the 2s head, the other one that is. its pretty much the same as the 3s one but with out the 90*bend
  • #10
    Dimitri
    REGISTER OR SIGN IN
    Happy time?
    ? it would bolt up and work definitely. with the stock clutch and flywheel etc.
    78's
  • Page 1 of 14 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
    1. RWD 3sge corolla $2800 ONO PICS
      By gottago in forum Cars for Sale (Toyota Only)
      Last Post: 7th May 2010, 01:10 PM
    2. tarago diff and rwd 3sge stuff
      By old_school_jap1 in forum Car Parts For Sale
      Last Post: 22nd February 2010, 10:16 AM
    3. Gen3 3sge RWD corolla in SYDNEY
      Last Post: 25th October 2009, 11:06 AM
    4. rwd 3sge. What dizzy???
      By egg_83 in forum Technical - Questions
      Last Post: 12th April 2009, 11:24 AM
    5. 3SGE RWD parts
      By 20valve69corona in forum Car Parts For Sale
      Last Post: 10th April 2009, 10:24 AM
