Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: W box info
    Mar 2010
    mark
    qld
    brisbane
    Hey, this could be well known I'm not sure but i was keen to know all this stuff and just stumbled across so thought id throw it up for everyone. ive never seen it till now
    the w55 seems the closest to t50, (ratio wise) and i love my ratios for our tracks so ill, prob stick close to them
    Veteran slydar's Avatar
    Dimitri
    bookmarked. good link, cheers.
    78's
    the w57 and w58 are meant to be "close ratio" boxes.
    the w57/8 both benifit from a 1.0:1 drive 4th gear.
    the main difference between the two is the overdrive gear (5th)
    with the w58 better for highway cruising
    the "W" box is almost identical on the outside. and made of alloy.
    the only way to tell them apart is to figure out the 5th gear ratios.
    so with the box on 5th gear, if you were to turn the input shaft 20x (cluch end), the tail shaft would turn.
    w55 23.53 turns
    w57 23.22
    w58 25.54
    the more turns you use, the more acurate the result i.e. w55 x 100 = 117.65 / w57 x 100 = 116.14
    so as you can tell this is really only good for w55/7 to w58 comparison
    to tell the difference between w55 and w57 select 1st and turn input shaft 20x, the tail shaft will turn
    w55 4.89
    w57/8 5.31
    this is the only way i'm aware of to identify these boxes without opening them?
    anyone correct me if i'm wrong
    Dimitri
    almost all factory rwd gearboxes have a 1:1 4th.
    55s have an alloy sandwich plate.
    57/58.. honestly, the difference.. who cares? condition is more important.
    78's
    <div class='quotetop'>QUOTE (slydar @ May 31 2008, 05:25 PM) </div>alot of people do mate.
    LIKE THE ONES TRYING TO FIGURE OUT IF THEY ARE ACTUALLY PAYING A PREMIUM FOR A W58 AND NOT GETTING RIPPED OFF!!!
    Dimitri
    why would you pay a premium for a 58 over a 57? theyre the same thing except a slight difference in 5th gear ratio.
    what i am saying is, id have a low k fresh import 57 over a worn out old 58 from some locally delivered shit box any day.
    78's
    <div class='quotetop'>QUOTE (slydar @ May 31 2008, 05:49 PM) </div>are you completely missing the point?
    dude i am providing objective information so that people have a guide to work it out for themselves.
    your opinion is great, and probably well supported. but its useless in telling the difference in the boxes. get the picture??
    Senior Member JoshKE's Avatar
    Josh
    Launceston
    lol, get angry mate, lol
    Senior Member xsoarerx's Avatar
    Logan City
    i drive both box'es... and theres really not much noticable difference between the w57 and w58, theres about 300 to 400rpm difference in 5th in a 6mge, my personal preference i'd say get the w57 or failing that just get the cheepest one.
    Ok
    Seamus
    Milton
    Easiest way to tell if you have a W58 (far easier than pulling it apart) is to just leave it out in the rain for a day..
    The iron/steel sandwhich plate will go a lovely rusty brown/black
    None of the others will do this, as they are all alloy
    ^ Clicky clicky!
  1. Replies: 3
    Last Post: 27th November 2011, 06:35 PM
  2. BT air box has the same mounting points as ST box?
    By Grant #2 in forum Technical - Questions
    Last Post: 8th August 2009, 11:02 PM
  3. T50 Box. Good cond, problem free box Price drop $300 obo
    By Maxhag in forum Car Parts For Sale
    Last Post: 10th September 2008, 12:40 PM
  4. Need info
    By takumi dorifto in forum Cars or Parts Wanted
    Last Post: 31st December 2006, 07:08 PM
