Results 1 to 10 of 14
Thread: 1GGZE starter motor on a 4age
    Senior Member 20v ae71's Avatar
    Dillon
    Default 1GGZE starter motor on a 4age
    I've seen this pop up a few times while reading about 4age/ae86 buildups and was wondering what the point of using them was?
    Is it better/faster cranking for higher compression engines or something?
    And do they sound any different?
    sound like wipper snippers with a side of larry king
    Quote Originally Posted by 20v ae71 View Post
    1watt reduction starter...needs a spacer tho...
    there is a 0.8, 0.9 and 1 watt reduction starter available from a ae92 that is bolt up
  • #4
    Anthony
    kilo watt
  • #5
    john
    nsw
    liverpool
    has any body ever thought or seen the starter motor mounted on the other side of the engine ... ????
    im using a bellhousing on my w58 to 4age that allows the starter motor to be mounted on either side ... im just not to sure if i mount it on the intake side it will work (spin the right direction )
  • #6
    Quote Originally Posted by Anthony View Post
    kilo watt
    thanks for correcting the typo...had only just climbed out of bed! RDO FTW
  • #7
    Quote Originally Posted by redsprinter View Post
    YES. 20V IS LIKE THIS FROM FACTORY FWD. DO IT.. DO IT.. DO IT.. ITS GOOD WHEN YOU HAVE TURBO.
    I just felt like caps.
    also the 1G starter motor adapters are available on yahoo. peace out from a brother from another mother.
  • #8
    john
    nsw
    liverpool
    thanks matt.
    and the idea came up beacuse my starter motor shit itself due to the heat off the turbo and exhaust ...
  • #9
    yer, get a 20v starter motor
  • #10
    Veteran driftke70's Avatar
    Ryan
    Buderim
    dude....
    thats why you flip it over when you move it across,
    wheelfriends.wordpress.com
  • Page 1 of 2 1 2 LastLast
    1. 4age starter motor
      By trikzlane in forum Cars or Parts Wanted
      Last Post: 14th March 2011, 08:51 PM
    2. 4age Starter Motor
      By mr.wikid.sik in forum Cars or Parts Wanted
      Last Post: 18th October 2010, 10:03 PM
    3. 4AGE Starter Motor
      By ke70 xx in forum Cars or Parts Wanted
      Last Post: 22nd June 2010, 11:58 PM
    4. 4age starter motor
      By callum1 in forum Cars or Parts Wanted
      Last Post: 6th April 2009, 01:04 PM
    5. 4age starter motor
      By Moebius in forum Cars or Parts Wanted
      Last Post: 13th March 2009, 10:57 AM
