Results 1 to 10 of 14
Thread: GZE, dead mid to top end
    Jason
    Gold Coast
    Default GZE, dead mid to top end
    Ive recently gotten my 86 going, there is still a vacuum leak (it keeps hunting for idol) which i still need to find. Everything else seems ok, timing is perfect, fuel pressure is good (adjusted the regulator to sit at 32psi at idol). And as far as i can tell ECU is fine.
    It hesitates to rev down low then revs well for a bit (about 1500 revs) then just goes dead.
    If anyone could give me an idea of what to check i would very much appreciate it.
    Cheers guys, Jase
    c
    What condition are the plugs in?
    Are you getting a strong spark?
    Jason
    Gold Coast
    good question, ill check them tomorrow. Also its an AE101 for a bit more info.
    thanks.
  • #4
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by ae86 slide View Post
    Cheers guys, Jase
    Well, first off i'd find that vacuum leak.
    Then if it's still actually misfiring, i'd check your ignition system.
  • #5
    Veteran slide86's Avatar
    Huw
    Hills
    you need to fix the vacumn leak first
    and its idle
  • #6
    Jason
    Gold Coast
    roger, will do. Didnt realise this could be messing with it so much,
    thanks again guys.
  • #7
    Josho
    thanks again guys.
    Absolutely!
    Had a bloke i know with similar problems to yours on his GZE - turned out he had a MASSIVE vacuum leak from his s/c inlet pipe which he'd made himself. His welding left alot to be desired.
  • #8
    Jason
    Gold Coast
    Well, i searched high and low, but no leak was found, also tried spraying water on suspect areas (ment to momentarily seal the leak).
    But i was speaking to someone tonight and they told me almost all ze's hunt for idol a bit.
    And i drove it the other day and it felt quite good, one thing that has me stumped though is that when i turn the ignition off it tries to run for a bit, is that another sign of a vacumm leak?
  • #9
    Mt Macedon
    Check all the obvious things like timing, cam timing, error codes, vac leaks again etc etc. There could be a number of reasons why it runs on, or runs badly.
    4AGZEs have a long inlet post-throttle, this means idle control is slow. Adding a frontmount cooler makes this problem worse. So sometimes the engine can "fall through" idle when clutching in from a few revs. You can up the idle speed a little or just cope and get used to toeing it a little as the revs fall. It can also result in hunting idle. On the stock computer some people seem to have hunting issues, others don't. With aftermarket ECUs the idle is a bit of a pain to tune nicely, but can be done.
  • #10
    Jason
    Gold Coast
    Yeah really not fussed about the idol, its a track only car anyway so its going to be full throttle or none. I will stop looking for a prob that doesnt exist, thanks for the help lads.
    Jase
  • Page 1 of 2 1 2 LastLast
    1. top dead center
      By nesta in forum Technical - Questions
      Last Post: 1st February 2011, 07:23 PM
    2. Wanted: Dead 4AGE alternators & starters, Dead T50's
      By Golberg in forum Cars or Parts Wanted
      Last Post: 7th January 2011, 08:49 AM
    3. 4AGE TOP END
      By haydenzz in forum Cars or Parts Wanted
      Last Post: 7th February 2008, 10:17 PM
    4. needs more top end
      By Will(SPA50) in forum General Topics (No Technical Questions)
      Last Post: 19th January 2008, 01:32 AM
    5. Where top dead centre is
      By Whip in forum Technical - Questions
      Last Post: 26th April 2006, 03:51 PM
