Results 1 to 10 of 18
Thread: Corona L.C.A's
    Senior Member koulouris#03's Avatar
    Nsw
    EarlwoodNsw
    Au
    Default Corona L.C.A's
    Hi guys.
    I am looking to undertake a corona lca coversion on my 86.
    What advise or info can you guys give me in regards to doing the job???
    Cheers.
    John.
    kiss ass like a bitch, so you can get ritch... but your boss gets ritcher of you!!!!
    Nsw
    EarlwoodNsw
    Au
    What kind of steering arms will i need???
    and why???
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by koulouris#03 View Post
    and why???
    The ones off your old LCA / strut.
    Why? Because the bolt spacing is different on Corona LCA's, also the steering arm is longer (slower steering speed).
  • #4
    Nsw
    EarlwoodNsw
    Au
    I have a sprinter... Will i need to change the steering arms???
  • #5
    Veteran Konakid's Avatar
    Henry
    Eastern
    No.....
  • #6
    性交を愛する marvis's Avatar
    Nope.
    Quote Originally Posted by trikzlane View Post
    I love streeting, Lowdown cars and watching the world unwind by every word Marv types.
    Quote Originally Posted by keiichi View Post
    dont you get raped by the police everywhere you go?
  • #7
    Nsw
    EarlwoodNsw
    Au
    so its just a straight bolt in???
  • #8
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    got to change the steering arms over.
    marvis says: This is incorrect information.
    FTP.
  • #9
    Veteran Nikkojoe's Avatar
    Tom
    Quote Originally Posted by Javal View Post
    Assuming they are xt130 lca's, the steering arms would bolt up to 86 struts (same bolt spacing, slightly different offset from balljoint though), but as said no point using them.
  • #10
    Veteran bigm's Avatar
    Gold Coast
    How to change LCA.
    1. Jack car up
    2. Unbolt LCA at cross member.
    3. Undo Caster Rod and Swaybar Link Pin
    4. Use a allan key to remove the bolts that hold the steering arm on the strut
    5. Remove Tie Rod End.
    6. Remove the whole control arm.
    7. Remove steering arm from the LCA
    8. Put the Steering arm on your Corona LCA
    9. Put everything back.
    10. Get a Wheel alignment
  • Page 1 of 2 1 2 LastLast
    1. will a xt133 corona pedal box fit into st141 corona
      By No Offence in forum Technical - Questions
      Last Post: 6th April 2012, 07:14 PM
    2. Corona
      By slideabout in forum General Topics (No Technical Questions)
      Last Post: 20th February 2012, 11:25 AM
    3. Replies: 5
      Last Post: 18th January 2012, 03:47 PM
