Results 1 to 5 of 5
Thread: 4agze stalls while driving
    Junior Member DIZZY's Avatar
    Daniel
    Vic
    Thomastown
    Default 4agze stalls while driving
    Hey guys need some HELP!! My car is a ae86 running a 4agze from a ae92.
    It was running fine till I got a front mount installed now it stalls when ever I let go of the accelerator and allow it to rev low ??? It also makes a popping noise when the supercharger kicks in, also when the car is off there's air still going through and pops near the exhaust manifold too ???
    Senior Member Stain's Avatar
    Derek
    Far North
    You might have a vacuum leak.
    c
    So it has a hunting idle? its due to the length of the intercooler lines,
    How big is your cooler?
  • #4
    Daniel
    Vic
    Thomastown
    my cooler is around length 50cm, height 30cm, thick 7cm just measured
    would a bov fix this problem??
  • #5
    Ryan
    bov is pretty pointless on a SC motor.. speaking from experience.. any FMIC on a 4agze that is relatively stock.. isn't a good idea.. its put down to your intercooler piping being a little too long...
    do you have an aftermarket ecu???
    there are few ways around it.
    1) get a small ass intercooler and exact to stock length pipes..
    2) get an aftermarket ecu , i got the mircotech.. and set the idle at 1100 and it solved this problems..
    are you running a thermostat?? i would assume this problem is even worse when the motor is cold?..
  • Similar Threads
    1. 4agze starts then stalls 1-2 sec later wtf
      By Sprintn in forum Technical - Questions
      Last Post: 22nd November 2011, 05:22 AM
    2. Replies: 7
      Last Post: 12th July 2011, 12:56 AM
    3. Driving with the driving club
      By flamingheads in forum Brisbane & QLD Events and Discussion
      Last Post: 1st December 2009, 07:13 PM
    4. Driving South.
      By focus_7 in forum Sydney & NSW Events and Discussion
      Last Post: 25th January 2009, 04:47 PM
