Results 1 to 10 of 18
Thread: 4agze to 4agte
    Default 4agze to 4agte
    I own a ae86 4agze and just starting 2 buy inlet mainifold, turbo mainfold and turbo just wondering if any one has tips in the process of change over its a map sensor'd 4agze will i get away without having 2 change the ecu and is there any big wiring changes that need 2 be done thanks
ID:	3513   Click image for larger version.
    Senior Member Intense's Avatar
    Aaron
    I met a guy at a cruise down here who had a 4agze with a t28 hanging off the side and the stock ecu so a standard ecu is definitely do-able
    Calvin
    Kilsyth
    after market ecu is desireable but stock will be fun. can't run that much boost on stock ecu though.
    T18 in the build
  • #4
    Senior Member Ae86sam's Avatar
    Manly
    I've done the same thing but i ran an Adaptronic ecu. There cheap enough to run and do 100 times better than a stock ecu..
    **Sorry not to really answer your question. Just my experience**
  • #5
    Mt Macedon
    OK, I haven't done this myself, but seen the results a few times.
    Just remove SC related stuff, bolt up turbo manifold, turbo and a suitable intake manifold. Sort out intercooler piping. Then the thing should run fine. I've seen it done on stock ECU plenty, and it works. Yes an aftermarket ECU allows tuning for improvements, but the stock one works.
    There'll be some vacuum lines that need to be rerouted/sorted out, but they are simple. Only electrical issues I can think of are TPS (which may just need a different plug, but I seem to remember some bigport to smallport TPS change on the NA manifold), and idle control (you can get by without it, use the temp controlled idle valve on the NA manifold or mount the ZE valve somewhere).
  • #6
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    yes very doable and i suggest everyone with a map 4agze in their car to do so. runs on standard ecu fine. 6psi on a t2 is plenty on a 4ag and i wouldnt run anymore than 8psi unless you have an upgraded driveline.
    be careful however how you shift if youre running a t50. a w5x would be the next step to take before an aftermarket ecu.
  • #7
    Senior Member .ady's Avatar
    Andy
    Footscray
    beau's done this .. im pretty sure he has ask him
  • #8
    Reeece
    Casula
    works great limited to about 12psi tho. http://www.youtube.com/watch?v=llY4e...e=channel_page
  • #9
    Junior Member bounceae86's Avatar
    thers a boost cut at about 13psi i think but can be sorted with an fcd
  • #10
    Reeece
    Casula
    maps have a 14.7psi boost cut .. AFM just blow up with unlimited boost
  • Page 1 of 2 1 2 LastLast
    1. Replies: 1
      Last Post: 3rd November 2010, 09:19 AM
    2. 4agze to 4agte help
      Last Post: 21st January 2008, 06:40 AM
    3. 4AGZE/4AGTE
      By asher in forum Cars or Parts Wanted
      Last Post: 9th January 2007, 07:38 PM
    4. 4AGTE with 4AGZE manifold
      By japlish in forum Technical - Questions
      Last Post: 12th September 2005, 10:38 PM
