Results 1 to 9 of 9
Thread: WTB: 16v 4AGE RWD Water Pump
    Default WTB: 16v 4AGE RWD Water Pump
    Heyas,
    I urgently need a 16v 4AGE RWD Water Pump. More specifically, I need the thermostat & thermostat housing that attaches to the waterpump.
    So even if you have a ceased, busted, old and/or broken water pump unit - I might be keen.
    I'm in Perth.
    Cheers,
    Daniel
    Senior Member gg004's Avatar
    Glenn
    Queensland
    Gold Coast
    you can get the whole water pump assembly from toyota, there not that dear
    2013 Toyota 86 GTS 4U-GSE
    1983 Toyota Sprinter AE86 4AGTE
    1967 Toyota Corona 1600S Coupe RT51 4R
    Veteran Nikkojoe's Avatar
    Tom
    You can use a 4ac rear housing (same thing). I have an old rwd 4age waterpump for $5, not sure how good it is (no corrosion inside). If not, you can buy a new rwd 4age waterpump for around the $80 mark from Auto1 (front half), or can use a 4ac which are the same thing internally (external casting needs one corner filed off - 2min job).
  • #4
    Default 4AC RWD Water pump housing
    On that note, does anyone have a RWD 4AC water pump housing & thermostat lying around??
  • #5
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Seriously, buy one new, crap old used 4AC pumps aren't going to last. The last one I bought cost me $45 from Repco.
  • #6
    Sorry to drag up this old post, but I still don't have a replacement for this. My waterpump is working fine, it's the thermostat housing that's busted.
    Just so there's no confusion, this is what i'm after.
  • #7
    And a thermostat as well!
  • #8
    buy a new thermostat
    and i have rwd one of those 4ac
    but wouldnt seperate from rest of pipes
    ae71 parts for sale stripping 3xae71's and a ke70
  • #9
    Lawrence
    Wollongong
    The RWD 4AGE thermostat inlet (as seen in the photo) is different to a 4AC one and will not work with the RWD alternator bracket.
    Just thought I should mention that.
  • Similar Threads
    1. 16v 4age rwd alternator bracket and water pump pulley
      By kid redonkulous in forum Cars or Parts Wanted
      Last Post: 28th January 2013, 04:56 PM
    2. WTB: RWD 4AGE Water Pump Pulley
      By 70XIN in forum Cars or Parts Wanted
      Last Post: 10th November 2010, 03:32 PM
    3. wtb fwd water pump pulley 4age 16v
      By kronix in forum Cars or Parts Wanted
      Last Post: 31st May 2010, 08:59 PM
    4. wtb 4age 16v fwd water pump pulley
      Last Post: 24th February 2010, 12:46 AM
    5. WTB 4age 16v RWD Water pump and piping
      By simonster in forum Cars or Parts Wanted
      Last Post: 25th October 2007, 02:44 AM
