Results 1 to 10 of 18
Thread: 4agze smallport map leads - part number
    Senior Member n00bvak's Avatar
    Novak
    SOR
    Exclamation 4agze smallport map leads - part number
    Hey Guys,
    Trying to chase down the part numbers for some ignition leads to fit my coil pack, smallport map 4agze. Looking for minimum 8mm leads too.
    Havent talked to toyota yet coz ill prolly get raped for shity thin leads.
    Tried top gun but they only have leads for dizzy smallport, same as every other parts place.
    Is there any other cars that use the same type of coils coz they seem to to be some random toyota coil that no one sells anywhere.
    If you can list the part numbers or where I can get them from that would be great. Its the last thing I need to start this puppy HELP!
    --- All your base are belong to Phil Bradshaw!!! ---
    <<< blog >>> build thread<<<
    Veteran Nikkojoe's Avatar
    Tom
    I got my last set from ben@kyp. Check if he has any (though they will be second hand). Mine were 7mm though (better than the standard 5mm).
    Novak
    SOR
    yer had a talk to ben, he couldn't find them when I was there last.
    I found that magnecor has a set of 8.5mm leads with a Perth distributer (A-1 Hi-Performance), just waiting for a price now.
    part number 45283
    Anyone else know where to get them?
  • #4
    Novak
    SOR
    k got a price, $115 + delivery. Not too bad for that price so I am going to pick up a set. Anyone else know of any other brands/places that sell leads for the DLI smallport?
  • #5
    Senior Member Moebius's Avatar
    Christian
    I got mine from top gun. DLI bigport 4agze, but shouldn't be any different to smallport right?
  • #6
    Novak
    SOR
    bigport did not come with DLI standard, only had dizzy, so your coil could be from a different car. (see the specs on phil bradshaws site)
    The smallport coils have a special clip on them, no leads I have seen before fit this. As far as I am aware it is unique to the ze smallblock.
  • #7
    Reeece
    Casula
    Bigports came in the ae92 AFM with CAS, so yes you could use the bigport 4agze leads on your smallport.. But make sure there to suit the coil pack type and not the dizzy. I usually get the bigport gze leads from topgun and get the plugs changed to suit coilpacks.. $90
    Quote Originally Posted by n00bvak View Post
  • #8
    Christian
    MR2 bigport gze had dizzy, ae92 bigport gze had DLI.
    Found the top gun box in the shed still, part number is TG4678. Price on the box was $75. I believe auto one ordered them in for me.
  • #9
    Novak
    SOR
    my bad,
    Cheers guys.
  • #10
    Junior Member rymax86's Avatar
    Ryan
    NOR
    Jus wondering which leads you ended up getting and where from because im stuck with the same problem to. Cheers
  • Page 1 of 2 1 2 LastLast
    1. Replies: 6
      Last Post: 11th January 2013, 05:03 PM
    2. Replies: 4
      Last Post: 23rd September 2009, 07:57 PM
    3. 4AGZE small port map sensor part number.
      By R&D Mechanical in forum Technical - Questions
      Last Post: 19th April 2009, 10:23 PM
    4. Need Part Number
      By Kamikaze in forum Technical - Questions
      Last Post: 8th August 2008, 04:47 PM
    5. part number for smallport fuel rail
      By orangechargd86 in forum Technical - Questions
      Last Post: 6th July 2007, 12:13 AM
