planning on running
neg-2.5 camber
zero toe
plus +3.0 castor
st141 corona,Daily driven/drifted
2mm toe out,(total)
-1.5 camber
+3.5 caster
Badly offset diff,lol,need a panhard!
43ger
Performance
SINCE 2008
-3.5 camber
+ 5 degrees castor
2mm total toe out
running t3 coilovers with t3 cambertops, t3 castor rods
PROTEK TYRE AND AUTO
SQ ENGINEERING
NCCE
whats the point in telling people what your going to run,
therefore you have no feedback/input into how it works for you?
i run
-2.5 camber
maxed stock castor rods
1mm toe out each side
love how chuckable it is, and how much steering input actually affects the car mid-slide (castor).
was running about 4mm each side toe out just for fun, to test the extremes i suppose, and was much more stable at high speed straight line, but less stable high speed slide! (~100kph)
Atm mine is,
-3.2 camner
+5 castor (might back it off, i wanna use my hands more)
1mm total toe out.
feels great, but also doesnt kill fronts too quick which is awesome.
i might be wrong here but...
just so yall know...
-toe = toe out and +toe = toe in
are you increasing castor on the left due to radial increase on the right when you sit in the car?
-3.2 camber
+2.3 castor
0 toe
feels good
I thought it was for when you fall asleep so you run off the road, not into oncoming traffic.
